January 17, 2024, 14:46 |
On the fly postprocessing of solutions
Ricardo Puente
Rep Power: 5 |
Hi all,
OpenFOAM has thise utility: https://www.openfoam.com/documentati...ldAverage.html This allows to calculate time averages and standard deviations on the fly, so that they can be dumped at the end of the simultion and analyzed without further postprocessing. I can't find anything similar in SU2, is it somewhere? If the answer is no, I might be willing to spend some time implementing it, and in addition some on the fly DFT utility. However I have not developed before with SU2, so I'd be grateful for any guidance to do so. I mainly want to avoid writing lots of vtks and postprocessing them after. Thanks, |
January 17, 2024, 16:12 |
bigfoot
Rep Power: 17 |
There is some info on the windowing averaging here:
https://su2code.github.io/tutorials/Unsteady_NACA0012/ And we have custom outputs that you can define using macro's: https://su2code.github.io/docs_v7/Custom-Output/ It would be nice to be able to define time-averaged outputs using the custom outputs. The main implementation is in COutput.* and CFlowOutput.cpp |
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 09:55 |
Steady Euler Solutions and the Effects of Dissipation | emellqui | Main CFD Forum | 1 | January 18, 2014 12:47 |
CFD Solutions & Training at affordable rate | BHE | Main CFD Forum | 0 | June 12, 2013 07:54 |
Analytical flow solutions | Antonio | Main CFD Forum | 0 | December 14, 2005 15:43 |
Analytical flow solutions | Antonio | Main CFD Forum | 0 | November 15, 2005 17:47 |
