SU2 Python Script AttributeError: 'CSinglezoneDriver' object has no attribute |
February 14, 2024, 23:57 |
Sean
Rep Power: 2 |
Hello SU2 Community,
I'm encountering an issue while running a Python script with SU2. I'm currently running a tutorial case on Static Fluid-Structure Interaction (FSI) using the SU2 Python wrapper. I am using the latest version of SU2 8.0.0 "Harrier", I'm facing the following error: Traceback (most recent call last): File "/path/to/your/script.py", line 116, in <module> main() File "/path/to/your/script.py", line 47, in main FlowMarkerList = FlowDriver.GetAllBoundaryMarkersTag() # Get all the flow boundary tags AttributeError: 'CSinglezoneDriver' object has no attribute 'GetAllBoundaryMarkersTag' I would appreciate any guidance or insights on how to resolve this. Thank you in advance! Last edited by bgulzar22; February 15, 2024 at 00:02. Reason: More Information |
python script, python script error, python wrapper |
Seeking Assistance with Enabling Python Wrapper in SU2 and Applying Variable Tempera | bgulzar22 | SU2 | 1 | January 30, 2024 09:34 |
python script to create geometry for salome, and then mesh | 6863523 | Mesh Generation & Pre-Processing | 4 | March 18, 2017 09:00 |
[General] Transfer variables into python script from bash-shell | cfdFreshman | ParaView | 0 | December 3, 2015 03:33 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
