Home > Forums > Software User Forums > SU2
Questions about zero-dimensionnal thermalbath
Like Tree2Likes
  • 1 Post By wallym
  • 1 Post By wallym
Old   March 3, 2024, 22:30
Default Questions about zero-dimensionnal thermalbath
AN
KleinMoretti is on a distinguished road
Hello,everyone!
I have read《SU2-NEMO: An Open-Source Framework for High-Mach Nonequilibrium Multi-Species Flows》 and would like to try to reproduce some simple examples.
The first is the zero dimensionnal thermalbath using N2 gas model. I tried to solve it with NEMO EULER, but I found a strange problem.
The result about Tve and Ttr is very similar to the picture in the article,but the N2 massfraction is a little higher than the convergence value in the article. My N2 massfraction convergence value is 0.7787, while the convergence value in the article is around 0.65.
The calculation of Tve and Ttr is related to the source term in the eve equation, the source term in the eve equation is related to wdot1 and wdot2. So the mass fraction and the temperature should be coupled together? Why is the temperature correct but the mass fraction wrong?
Thank you in advance for your time and consideration. I truly appreciate any insights or advice you may have to offer.
KleinMoretti is offline   Reply With Quote
Old   March 4, 2024, 18:48
Wally Maier
wallym is on a distinguished road
Hiya!
Thanks for using SU2-NEMO and posting your question here!
You are correct that there is a coupling between the chemistry and thermal nonequilibrium terms. Would you mind posting your configuration file? I can take a look to see if I can find anything.
Do you have the FROZEN_MIXTURE option as YES?
I hope this helps,
Wally
KleinMoretti likes this.
wallym is offline   Reply With Quote
Old   March 4, 2024, 22:38
AN
Originally Posted by wallym View Post
Hiya!
A N2 concentration of 0.7787 is nearly atmospheric which definitely shouldn't be the case if you are ending with a temperature of nearly 7500K. Do you have the FROZEN_MIXTURE option as YES?
I hope this helps,
Wally
Hello wallym, thank you very much for your reply.
As you said, I didn't set FROZEN_MIXTURE=YES. I just tried to set it to YES,then N2 massfrac is always 1 and N massfrac is always 0, and the convergence temperature becomes about 14000K.
Old   March 4, 2024, 22:52
AN
Thank you again for your kind reply!This is my config file.
Old   March 5, 2024, 16:51
Wally Maier
Awesome, it looks like your config is set up properly - and matches the case file that I have.
Ahh, sorry. The plots you are referencing include molar fraction, not mass fraction. If you convert to mole fraction, your results should match up.
Let me know how those compare.
Wally
Old   March 5, 2024, 20:47
AN
Wally
It was so careless of me.Thank you very very much for your help! Now the result is correct!
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[ICEM] Complex geometry mesh general questions Jack B ANSYS Meshing & Geometry 0 August 14, 2019 13:44
General questions about how to mesh and build up my case ThunderstruckGER OpenFOAM 5 September 23, 2018 18:33
possible interview questions atturh Main CFD Forum 1 February 21, 2012 08:53
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 14:39
