Questions about zero-dimensionnal thermalbath |
March 3, 2024, 22:30 |
AN
Rep Power: 2 |
Hello,everyone!
I have read《SU2-NEMO: An Open-Source Framework for High-Mach Nonequilibrium Multi-Species Flows》 and would like to try to reproduce some simple examples. The first is the zero dimensionnal thermalbath using N2 gas model. I tried to solve it with NEMO EULER, but I found a strange problem. The result about Tve and Ttr is very similar to the picture in the article,but the N2 massfraction is a little higher than the convergence value in the article. My N2 massfraction convergence value is 0.7787, while the convergence value in the article is around 0.65. The calculation of Tve and Ttr is related to the source term in the eve equation, the source term in the eve equation is related to wdot1 and wdot2. So the mass fraction and the temperature should be coupled together? Why is the temperature correct but the mass fraction wrong? Thank you in advance for your time and consideration. I truly appreciate any insights or advice you may have to offer. |
March 4, 2024, 18:48 |
Wally Maier
Rep Power: 7 |
Hiya!
Thanks for using SU2-NEMO and posting your question here! You are correct that there is a coupling between the chemistry and thermal nonequilibrium terms. Would you mind posting your configuration file? I can take a look to see if I can find anything. Do you have the FROZEN_MIXTURE option as YES? I hope this helps, Wally Last edited by wallym; March 5, 2024 at 16:59. |
March 4, 2024, 22:38 |
#3 | |
AN
Rep Power: 2 |
As you said, I didn't set FROZEN_MIXTURE=YES. I just tried to set it to YES,then N2 massfrac is always 1 and N massfrac is always 0, and the convergence temperature becomes about 14000K. |
March 4, 2024, 22:52 |
AN
Rep Power: 2 |
Thank you again for your kind reply!This is my config file.
March 5, 2024, 16:51 |
Wally Maier
Rep Power: 7 |
Awesome, it looks like your config is set up properly - and matches the case file that I have.
Ahh, sorry. The plots you are referencing include molar fraction, not mass fraction. If you convert to mole fraction, your results should match up. Let me know how those compare. Wally |
March 5, 2024, 20:47 |
#6 | |
AN
Rep Power: 2 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[ICEM] Complex geometry mesh general questions | Jack B | ANSYS Meshing & Geometry | 0 | August 14, 2019 13:44 |
General questions about how to mesh and build up my case | ThunderstruckGER | OpenFOAM | 5 | September 23, 2018 18:33 |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 08:53 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 14:39 |
