Home > Forums > Visualization & Post-Processing Software > Tecplot
Semi-Circle in Tecplot.
Like Tree2Likes
  • 2 Post By scott_rumage
Old   July 31, 2014, 04:25
Default Semi-Circle in Tecplot.
MAT
mmatadu is on a distinguished road
Hello All,
I would like to know, how can I write ASCI data file for semi-circle. I know it for circle:
[[Suppose the following example for circle of radius 20 at center(30,30)
GEOMETRY X=30, Y=30, T=CIRCLE, FC=BLUE, C=GREEN
20
Similarly, if any option to write semi-circle, please inform me.
Sincerely yours
MAT
mmatadu is offline   Reply With Quote
Old   July 31, 2014, 10:54
Scott Rumage
scott_rumage is on a distinguished road
In Tecplot 360 EX go to Data>>Create Zone>>Circular …
- For example -- create a zone of 10x25x1
Next go to Data>>Extract Subzone…
- Change the J-Index from “Mx” to “13” (extracts a semi-circle zone)
Next go to File>>Write Data File>>
- Export the Subzone to an ASCII data file (*.dat extension)
- I suggest that you select “point” format (versus “block”)
You now have an Tecplot ASCII data file of a half circle.
Cheers,
Scott
ronithstanly and SHUBHAM9595 like this.
scott_rumage is offline   Reply With Quote
Old   July 31, 2014, 12:21
Default Thank you very much and one more thing Please
MAT
Dear Scott,
Its great, thank you very much. I can draw the semi circle in Tecplot.
Actually, I am using FORTRAN code in my CFD simulation. In 2D case, if I want to create geometry like a circle, for example: a circle of radius =10 , Centre (50,20), in my FORTRAN code, I have defined the following way and in my output results file, Tecplot-360, 2010, I have seen geometry (circle).
WRITE(*,*)'GEOMETRY X=',50, ',','Y=',20,',' ,'T=CIRCLE', ',',
& 'C=BLACK',',','FC=BLACK', ',', 'CS=GRID'
WRITE(*,*)10
Now my problem is: For semi-circular geometry(upper half), how can I write the statements in my FORTRAN code (like above statements for circle)?
Please help me in this regards.
Sincerely yours
MAT
Old   July 31, 2014, 16:39
Scott Rumage
Sorry Matt, I have no suggestions. Scott
Problem with circle sampling type, of Sample utility nik OpenFOAM Post-Processing 4 May 29, 2017 05:27
Subtraction of a circle from a rectangle,Gambit engahmed ANSYS Meshing & Geometry 2 May 17, 2010 01:08
Having trouble getting a circle to fall through water ozirock FLUENT 0 January 28, 2010 12:57
Find perpendicular intersection bet. pt & circle zonexo Main CFD Forum 3 July 27, 2007 08:53
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
