Home > Forums > Visualization & Post-Processing Software > Tecplot
airfoil in tecplot
Old   November 24, 2007, 03:20
Default airfoil in tecplot
sudhakar
Hi all,
I have obtained rseults for incompressible flow over airfoil at angle of attack and I am using Tecplot as a postprocessing tool. In Tecplot, there is provision for including basic geometries like circle, square and ellipse into the plot window. Is there any way to import the coordinates of the airfoil, so that the geometrical shape can be included in the stremline or vorticity contour plot? thanks for your views..
Old   November 24, 2007, 09:07
Default Re: airfoil in tecplot
Ruben Paredes
Hi Sudhakar,
You should write a dat file and load it to Tecplot using a reader, I use the Tecplot data loader but I think that you can use any of them, depending of the format of the dat file.
This is a sample of a XY plot type.
TITLE="Simple Data File" VARIABLES="ITERACOES", "RESIDUE" ZONE I= 10 DATAPACKING=POINT
x1 y1
x2 y2
x3 y3
x4 y4
x5 y5
x6 y6
x7 y7
x8 y8
x9 y9
x10 y10
Regards, Ruben
Old   November 25, 2007, 00:45
sudhakar
thank you very much Ruben.. I got it..
Low Speed Airfoil Mancusi FLUENT 7 April 3, 2014 06:11
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 11:31
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
