April 21, 2016, 00:50 |
Forces and Moments over a 2D slice
Ali
Rep Power: 16 |
I made a slice of a wing section along the span (becomes 2D airfoil). Now I would like to integrate/wish to calculate forces and moments on that sliced @D section. How can I do that?
Best Regards Ali |
April 22, 2016, 10:52 |
Scott Rumage
Rep Power: 16 |
This calculation is performed via the "Analyze" section of Tecplot 360 (found on the top menu bar). I would recommend a thorough reading of the Tecplot 360 manual's chapter 21 titled "CFD Data Analysis" (page 303) to learn how to do this work. Here is a link to the manual: http://download.tecplot.com/360/curr...ers_manual.pdf .
Ali, I do recall that you have had an issue with downloading from Tecplot's web-site in the past, but that web-site is active and so the issue is probably on your end. I note that you are located in Pakistan. If your Tecplot license is under maintenance support, you can also contact Tecplot's distributor Genias Graphics www.genias-graphics.de for assistance in answering this question. Good luck, Scott |
Ensight: Visualizing forces and moments | David | EnSight | 3 | December 19, 2012 13:47 |
Workbench 12.1 reaction forces and moments in response spectrum | KOHCTPYKTOP | ANSYS | 0 | November 12, 2011 04:42 |
forces and moments | nico | Main CFD Forum | 0 | January 28, 2008 07:25 |
Compute CEs from moments and forces | nico | Main CFD Forum | 1 | August 6, 2007 19:19 |
Hydrodynamic forces and moments on submarines | Peo Hedin | Main CFD Forum | 2 | July 20, 1999 02:53 |
