Home > Forums > Visualization & Post-Processing Software > Tecplot
velocity vector on 2d plane not 3d
Old   December 29, 2016, 05:12
Default velocity vector on 2d plane not 3d
akbar.mech is on a distinguished road
hi
I am simulation swirling flow in fluent. when i want to see the velocity vectors in fluent, i define a plane and in the vectors menu, i choose that plane to show the vectors on that and from the vector options select the "in plane" button to show the vectors inside the plane i have defined.
now my question is:
how can i do the same in tecplot? because when exporting data to tecplot there is no "in plane" option.
any help is appreciated
akbar.mech is offline   Reply With Quote
Old   January 1, 2017, 12:06
any idea ?!!!!
Old   January 5, 2017, 14:57
dan
deenriqu is on a distinguished road
It's difficult for me to see exactly what you want. But let me know if this helps,
(1) create a slice in your 3D geometry. Define the position and plane normal.
(2) then Data>extract> Current Slice (NOTE: this is not available in certain versions of tecplot)
(3) Change the plot type to 2D Cartesian
(4) Figure out how to plot the vectors here
deenriqu is offline   Reply With Quote
Old   December 1, 2017, 13:47
Default vector in 2d plane
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I have the same problem. Actually, I am simulating a flow which is rotational in (or say ) helical in a tube. Its sort of rotational periodic segment. I want to see velocity vectors in a 2dplane, that I made in Fluent but it does not show rotational flow in vector plots/ Now I want this in TEcplot. And there too it does not show vectors rotating. Where I am doing wrong?
Fluent inputs
mas flow inlet
x,y and z direction = 0 0 1 (Cartesian X, y and z)
Rotation about z axis
Flow is rotational periodic about z axis.
Tecplot
Do I need to change vector from u v w velocities corresponding to x, y and z directions?
Shamoon Jamshed is offline   Reply With Quote
Old   December 2, 2017, 10:40
dan
It's difficult to say exactly why your vectors aren't plotting for correctly. make sure that the correct variables are assigned to the correct velocity/cartesian components would be a good start
Old   December 2, 2017, 11:03
Shamoon Jamshed
Actually I did this, but the problem is not solved. Do I have to use some equation(s) , some conversion for velocity components or so?
Old   February 25, 2018, 14:22
Shamoon Jamshed
any idea please?
Old   May 23, 2019, 10:40
Saman95 is on a distinguished road
hello dear
I want to plot velocity vector for a 2d case in CFD- post but I received an error as:
" variable velocity is not a variable vector."
I export velocity vector as variable from Ansys fluent.
can anyone help me?
Saman95 is offline   Reply With Quote
conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result. sharonyue OpenFOAM Running, Solving & CFD 12 April 9, 2016 23:30
Superimposing a developed Velocity Profile at a different plane hasanifte FLUENT 8 March 30, 2015 19:47
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 22:34
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 16:28
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
