How to scale the axis in Tecplot like the fluent scale function |
July 2, 2020, 16:24 |
Rep Power: 9 |
How to scale the axis in Tecplot like the fluent scale function? I do not need the data in decimal, can we change it into interger?
July 2, 2020, 18:46 |
Rep Power: 12 |
Plot> Axis > Range(tab)> Dependency and set the setting to independent and you can use the x to y ratio to change the ratio displayed on the plot.
If you want to change the data itself rather than the plot use Data> alter> specify equations and alter the data. |
July 3, 2020, 15:49 |
Thank you, the second one is the one I want, I have another two question: 1. How can
#3 | |
Rep Power: 9 |
1. How can we set the title name of axis as italic? 2. Could we plot path line (not streamline) in Tecplot? |
July 6, 2020, 14:29 |
Rep Power: 12 |
1) double click on the axis title and it will launch Axis details with the axis title tab and then click the italic button and tada your title should be italic
2) Analyze > Particle Paths and Streaklines should be what you are looking at. Have a look at the help button there to read how to use them. |
July 7, 2020, 17:21 |
Do you have any vedios to discribe it clearly, I find the help is not very good to le
#5 | |
Rep Power: 9 |
July 8, 2020, 15:52 |
Rep Power: 12 |
This is the closest we have at this point.
https://www.tecplot.com/2014/10/31/s...article-paths/ Feel free to contact support@tecplot.com if you have additional specific questions. |
July 8, 2020, 17:42 |
Thank you , I see it, but it is not what I want , can you give a vedio about the path
#7 | |
Rep Power: 9 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
