Home > Forums > Visualization & Post-Processing Software > Tecplot
Integration over arbitrary volume
Old   November 17, 2020, 09:54
Default Integration over arbitrary volume
Adrian Chaves
Adrian_chaves is on a distinguished road
Hi everyone,
I am simulating the aerodynamic flow over an aircraft flying at high subsonic. I want to perform 3D (volume) and 2D (surface) integrals of some specific variables (definition of which is not relevant to this post). Only half the plane has been simulated with a mesh of almost 11 million cells (mesh depicted in the following images, where the circular shape corresponds to the simmetry plane). The mesh is multiblock, FE - Brick in Tecplot.
The issue is that I do not want to integrate over the whole volume but just over a specific range. Imagine, for instance, a rectangular control volume around the aircraft that only extends up to two aircraft lengths:
2D surface integrals do not seem problematic. I can create slices at arbitrary X, Y or Z locations, which correspond to the "faces" of the rectangular control volume, and perform the integrals once the slices have been "extracted". Tecplot allows me to select, for example, a specific X location where I place my slice and I assume that it interpolates the variables at that plane.
However, I cannot select the specific X,Y and Z range in which I want to perform the volume integrals. I've tried with "Value Blanking", but the consequent volume is dependent on the cell distribution. In the image below, the values have been blanked with the idea of obtaining a rectangular shape similar to the depicted above. Thus, I cannot, for instance, place the outer boundary of the volume at an arbitrary Xmax perpendicular to freestream velocity.
An alternative approach I've tried is to interpolate the data from the initial fluid volume (using the inverse-distance interpolation method) onto the rectangular domain. The idea is to generate an ordered zone where I can perform the integrals. However, this method seems extremelly computationally expensive, particularly because it does not allow me to generate a finer mesh towards the surface of the airplane.
How can I then perform 3D volume integrals over specific volumes inside the fluid domain? Any ideas/suggestions will be appreciated.
Thank you for your time.
Adrian_chaves is offline   Reply With Quote
Old   November 18, 2020, 14:09
novedevon is on a distinguished road
You have described the best options for doing as you want there really isn't any other method. Although Linear Interpolation will likely be slightly faster than inverse distance.
novedevon is offline   Reply With Quote
Old   November 19, 2020, 05:38
Adrian Chaves
Thank you for your answer!
If that is the case, ins't interpolating a really inefficient method? After all, I only want the integration volume to have a specific shape (e.g. rectangular shape). All the flow field data inside the integration volume does not need to be modified/interpolated. In other words, only the data at the boundaries needs to be interpolated to adapt to the defined shape. This would mean that perhaps only less than 1% of the total cells within the volume would be interpolated, saving a huge amount of computing resources.
The surface integrals at the boundaries are properly defined, as tecplot interpolates the data at a exact location when you create a slice. However, it does not work the same way for 3D integrals, for which you cannot define the exact limits of integration (at least for an unordered mesh). I was wondering if there is any approach that allows you to do this.
Old   November 19, 2020, 12:13
How are you defining the rectangular shape? You may be able to define a zone which is surfaces of the rectangle thus only interpolate to those.
It may be easier to do this via email or a phone call, give support@tecplot.com an email and we will see what we can do.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
