Visualizing Velocity Vectors in 2D Plane from Quiver Data |
Ruby
Rep Power: 0 ![]() |
For background: I am using videos to determine smoke flow through a nozzle and using Matlab command 'opticFlow' to get the Vx and Vy components of the velocity vectors. I had initially used the 'Quiver' function to get the most accurate image of vectors however I was not able to export the actual quiver data of (u,v,x,y) so had to use the Vx and Vy components individually. Now, I have the experimental data from Matlab where I have the x-component and y-component of my velocity vector, Vx and Vy, respectively. This is then put into excel and imported into Tecplot (using the add-in). My problem is that Tecplot plots each component in a separate zone, thus just plotting the data 1 on top of the other and not together into 1 velocity plot. Is there any way to plot both Vx and Vy into the same sheet to get 1 velocity plot? They both have the same x and y positions so my variables would be (x, y, Vx, and Vy). Any help would be appreciated. Thanks. |
Scott Fowler
Rep Power: 15 ![]() |
It sounds like you may want to create a 2D contour plot showing your velocities? Or a 2D vector plot?
If so, you may need to use the Tecplot add-in as explained in this video: https://youtu.be/gmHHgIYGWyU?t=75s If you're still having trouble getting your data in, reach out to support@tecplot.com. |
Display Modes | |
Filtering Velocity Vectors + Creating meridian planes | L4M496 | FLUENT | 0 | December 28, 2020 09:15 |
Mapping velocity data to a boundary | cyln | OpenFOAM Running, Solving & CFD | 1 | July 22, 2017 16:13 |
[CFD-Post] Using data from inserting a plane | siw | CFX | 1 | September 8, 2010 08:57 |
Velocity vectors | SA | Main CFD Forum | 1 | March 8, 2007 02:04 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
