Home > Forums > Visualization & Post-Processing Software > Tecplot
Max value in the extracted line
Old   May 15, 2023, 22:40
Default Max value in the extracted line
Ramesh K
RameshK is on a distinguished road
Send a message via Yahoo to RameshK
Hi
I want to know if there is any way to find out the maximum value of a variable on an extracted precise line. I would like to use it to normalize the data on that line with the maximum value.
I looked at maximum but it needs two values for comparison.
Regards
RameshK is offline   Reply With Quote
Old   May 22, 2023, 17:58
Brandon M
Brandon_CFD is on a distinguished road
Hello Ramesh,
You can go to Data>Data Set Info, select your extracted line zone, and use the maximum variable value. Use this value in the Specify Equation dialog to normalize the variables of interest.
There are also ways to automate this process using our Python API (PyTecplot).
If you have any questions about this workflow, please reach out to support@tecplot.com.
Brandon_CFD is offline   Reply With Quote
Old   May 22, 2023, 22:57
Ramesh K
Originally Posted by Brandon_CFD View Post
Hello Ramesh,
Hello Brandon
yes I know this but if I have to use the maximum value or minimum value of a particular variable in the dataset, what is the command that is required to be used is the precise question.
currently I am manually copying the maximum value in order to automate it what is the process ?
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Issues With Exporting From GMSH rberdon Mesh Generation & Pre-Processing 0 February 11, 2021 11:11
Converging Diverging Nozzle with dbnsTurbFoam Saleh Abuhanieh OpenFOAM Running, Solving & CFD 4 December 13, 2019 10:26
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
