Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
Quality criteria for fluent
Old   March 1, 2016, 04:01
Post Quality criteria for fluent
blake
blake_varun is on a distinguished road
hello friends,
am making a mesh using ansa and going to analyse it in Fluent.
can anyone please tell me about what quality criterias should be activated in ANSA and their values....
Thank You
blake_varun is offline   Reply With Quote
Old   March 3, 2016, 14:48
Vangelis Skaperdas
vangelis is on a distinguished road
Hi there
If you start ANSA in CFD layout
the default quality criteria are good for Fluent cases.
Just switch to Hidden view mode to see if there are any
elements not meeting these criteria.
You can have even more quality criteria settings
if you use the UDF>Set Quality Criteria
Accessible from the
Second icon at the top from the left
UserScriuptButtons
Hope this helps
Vangelis
vangelis is offline   Reply With Quote
Old   March 5, 2016, 08:05
Post
blake
thank you so much vangelis..
am meshing a truck for the aerodynamic study...
initially i went with the default quality criteria in ANSA CFD...
but when i read that mesh in fluent and checked the quality, the orthogonal quality is below 0.01....it should be above 0.01....
So i went back to ansa and generated a new mesh with the "non-orthogonality" quality criteria checked....
this time The volume elements which failed the orthogonal quality where in the layers...
can you plz suggest any method to create the layers with no "non-orthogonal" issues...
Old   March 6, 2016, 12:38
Vangelis Skaperdas
You have done well activating Fluent orthogonality
How many elements were violating the limit of 0.01
Have you tried the function
Volumes>Improve>Fix Qual>Visible?
This should fix the bad elements
Old   March 6, 2016, 23:49
Post
blake
in the non-orthogonality quality criteria i had given 0.1
so there where some 3000 off elements...
i had also used the improve>fix quality>visible as well as improve>reconstruct>visible...
even though some 200+ elements are remaining...the improve function is not working on them...
Should i reduce the orthogonality quality value further????
all the elements are in layers...
Old   March 7, 2016, 02:46
Vangelis Skaperdas
I suggest you only use Improve Fix Qual, as reconstruct can only work on tetra mesh.
Fluent orthogonality of 0.1 is too strict.
Usually Fluent complains for orthogonality less than 0.01.
I suggest you re-apply Fix Qual on the original mesh, prior to fix qual with 0.1,
so that you start fresh this time with a target value of 0.01
General mesh quality criteria daniel.struwig Fidelity CFD 3 October 3, 2017 03:53
[ICEM] Mesh quality criteria in ICEM Chander ANSYS Meshing & Geometry 13 September 5, 2017 08:52
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? Rohith Giridhar ANSYS Meshing & Geometry 2 July 11, 2015 18:04
[ANSYS Meshing] Fluent quality criteria in AM and Gambit Far ANSYS Meshing & Geometry 6 March 24, 2012 03:35
ICEM CFD - preset quality criteria JSM CFX 2 May 7, 2008 23:36
