[ANSYS Meshing] How fine must a mesh be for flow over an airfoil
Old   May 3, 2012, 16:55
Default How fine must a mesh be for flow over an airfoil
mzamora
nottern is on a distinguished road
I've been working in a 3D simulation about a crossflow water turbine. Due to restricted RAM resources, my mesh was limited to a specific size.
I ran some 2D cases and with finer meshes there are still changes.
I'd be pleased to find some references about how fine a mesh might be when modelling flow over airfoils (even if in this case are hydrofoils)
Thanks in advance for your help
nottern is offline   Reply With Quote
Old   May 4, 2012, 12:54
PSYMN's Avatar
Simon Pereira
There are too many variables for a rule of thumb... (Although if someone has some ideas, please share)
What you should do is a mesh refinement study. Create several meshes, each one finer than the next, run them all and see if you start to get the same answer between any two meshes...
For instance, if you have several meshes where 1 is the most coarse and 5 is the most fine, and if 4 and 5 agree on the answer (and are correct), then you know that you only need to refine up to the level you did in mesh 4. Any extra refinement (to get up to the level of mesh 5) was not helpful.
Try this refinement study on a simple model (just a wing or something) under similar operating conditions to your real model, then you can apply that ideal refinement to the real model...
CFD Online Users Survey
Old   May 4, 2012, 13:12
Default I tried that in 3D
mzamora
I did a mesh refinement study in 3D. It was a pain in the neck, because I work with a complicated geometry and the RAM limited my finer mesh size. But, as I wrote first, looks like then when I compared in 2D with a finer mesh (I couldn't made that kind of mesh in 3D) I just noticed it wasn't enough.
I was thinking someone may have tried to make a correlation between some adimensional numbers and number of divisions, something like that. It's pretty difficult to find the info about mesh validation in papers (I'd try do the correlation if I had time and info)
Thanks anyway
airfoil, element size, mesh
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
dynamic mesh airfoil oscillation aamer Fluent UDF and Scheme Programming 0 January 25, 2011 07:29
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
