[ANSYS Meshing] How to include an internal surface in fluid vol
Old   May 4, 2012, 11:10
Default How to include an internal surface in fluid vol
James Willie
jwillie2000 is on a distinguished road
Hi All,
I have a case where i have to model a heat exchanger geo. The fins are in a channel and through this channel air is flowing. The air is the fluid that i want to model as it flows through this channel but i want the fins to be included in the fluid simulation with walls boundaries assigned to them. My problem is that when i use the "fill" option i am able to extract the fluid volume and i can also mesh it (both fluid and fins) but when i import it into fluent only the fluid seems to be appearing. The fins or the surfaces defining the fins do not appear. I remember that in ICEM CFD, one can include an internal surface within a fluid volume. Any idea how to work around this problem?
In my DesignModeler, the fins are appearing as "Surface bodies" and the channels as "Solids"
Thanks!
Jimmy
jwillie2000 is offline   Reply With Quote
[OpenFOAM] How to calculate the fluid flow through a surface lynx ParaView 4 January 20, 2016 11:58
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
