[ICEM] how to mesh a pack bed reactor with contact spheres using ICEM? |
November 20, 2016, 22:47 |
SNOW
I want to calculate the heat transfer and pressure drop through a packed bed, so firstly , i create a random packed bed using DEM method,then i got the spheres coordinates. Secondly, i transfer the geometry to ICEM and mesh.
There are some problems i can't continue: 1:the contact point distort the mesh; 2:i use tetra+prism to mesh ,but the quality is too low to calculate. 3:there are so many cells for only 100 spheres, which took too much time to mesh. So i want to know if anyone can share a more convenient method to mesh the spheres and if i have as up to 10000 spheres, how to mesh using ICEM? Thanks! Last edited by NIU; November 21, 2016 at 05:17. |
November 15, 2021, 12:09 |
saidc
Rep Power: 6 |
Hi NIU,
Were you able to solve your problem? I'm facing same difficulties right now. Lot of spheres, 50 million cells but still too coarse to solve. The best result I get with Salome (NETGEN Algorithm) for now is 5000 non-orthogonal > 70 faces (avg 20, max 88). Same as you I have a lot of spheres (300,900,2000 and so on). I know that if I use much lower max size parametre for NETGEN mesh will be fine but it is already has more than 50 million cells and this is not even the largest case I have. I wonder how did you approached this situation because I'm using OpenFOAM and SALOME unlike you. Please share your experiences with me. Kind regards, Said. Last edited by saidc.; November 15, 2021 at 14:30. |
November 15, 2021, 18:26 |
Gert-Jan
Rep Power: 27 |
Quality is mainly determined by the contact angle between the spheres. If you use point contact, then you can imagine that none of all existing mesh packages is able to create good quality mesh. Therefore you need a compromise between real geometry with impossible mesh or a simplification (with overlapping spheres) with reasonable mesh.
Moreover, try CFX as a solver which is very forgiven for low quality (=bad) mesh. |
November 16, 2021, 05:16 |
#4 | |
saidc
Rep Power: 6 |
Thanks for your kind reply. I already did overlapping for ensure that the mesh can be done but that approach still not cover the problem. If I do much more overlapping (decreasing the distance) my needed porosity will gone and my accurisy too. I'm still thinking what should I do and my time running out. Umarım çözümü en kısa sürede bulurum. Kind regards, Said. |
November 16, 2021, 05:24 |
Gert-Jan
Rep Power: 27 |
Around the the contact point you can create a small cilinder as part of the spheres. This will at least remove the very small angle.
icem 17, packed bed |
ICEM of ANSYS V15: how to export .msh mesh for CFX | hydroaero | CFX | 1 | March 9, 2015 22:15 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 05:10 |
[ANSYS Meshing] Question about ICEM mesh output to CFX | lnk | ANSYS Meshing & Geometry | 0 | July 27, 2012 15:39 |
Boddy fitted Hexcore Mesh in ICEM Cfd | Mitch | CFX | 0 | December 29, 2008 06:07 |
How to do Geometry from 3D mesh in ICEM | San24 | Main CFD Forum | 4 | August 8, 2005 02:49 |
