[GAMBIT] Domain help...
Old   May 30, 2012, 09:12
Default Domain help...
abishai murday
ACER is on a distinguished road
Hi everyone
Could someone help me on this, i have my airfoil and 2 faces round it. The bigger one is the domain and the smaller one is to have better control over the meshing around the airfoil...the only problem im facing is how to use the boolean. I want the inner rectangle to be still connected to the outer one as one whole face while having the aifoil extracted from it....any suggestions??
http://img267.imageshack.us/img267/5743/57055510.png
thank you
ACER is offline   Reply With Quote
Old   May 30, 2012, 09:36
-mAx-'s Avatar
Maxime Perelli
Are you refering to this thread?
http://www.cfd-online.com/Forums/ans...hing-help.html
Let's say you have your big rectangle and your airfoil (already splitted >> hollow)
Then split the domain with the edges from small rectangle
Old   May 30, 2012, 12:04
abishai murday
HI Max
yea its from the thread before...so basically you are telling to first apply the boolean on the airfoil from the inner box then split the inner box from the outer domain...
thanks again
Old   May 31, 2012, 00:41
-mAx-'s Avatar
Maxime Perelli
I adviced you to split your domain with an ellipse or a circle.
Your rectangle edges won't be at equi-distance from your airfoil.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
