[ICEM] 11738 cell(s) have node(s) not connect to all faces (on 0)
Old   July 29, 2014, 13:05
Post 11738 cell(s) have node(s) not connect to all faces (on 0)
Xu
seeking is on a distinguished road
I met the problem when I check mesh in Ansys fluent as the title tells.
I used ICEM to generate the mesh. The quality is fine. I don't know what results in the problem. Does anyone know how to solve this problem? Thank you.
regards,
Xu
seeking is offline   Reply With Quote
Old   August 1, 2014, 10:51
Unhappy
Xu
I found that if I use "refinement" function in ICEM I will meet the problem. if I don't use it, there is no problem when checking mesh in ANSYS fluent.
Anyone knows why?
Old   August 2, 2014, 16:59
Sebastian Engel
bluebase will become famous soon enough
I experienced the same issue with the refinement feature of icem and fluent. Probably, the usual way to export the blocking to fluent doesn't cover the hanging nodes (and faces). I don't know a solution to this problem but Fluent has some refinement features itself (e.g. adapt by region).
bluebase is offline   Reply With Quote
Old   August 4, 2014, 04:32
Xu
Thank you. Can I only refine one direction(for example, refinement alone z axis) in fluent?
ansys fluent 14.5, icem
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
elements, nodes and faces Andy CFX 10 July 7, 2013 22:40
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
