[ANSYS Meshing] Blade tip blocking
Like Tree6Likes
Old   January 29, 2013, 09:28
Default Blade tip blocking (icem)
Francisco
Bollonga is on a distinguished road
Hi everybody,
I'm meshing a three blade wind turbine and some blocking located at the blade tip are causing me trouble.
In the 1st picture you can see the blade tip with sharp trailing edge and its blocking. There are O-grid blocks around the blade and then all edges converge to a unique vertex in the very extreme of the tip + O-grid distance (vertex 624).
In the message box you can see that a collapsed edge is causing an internal error. This is causing negatives volumes as it is shown in the histogram (negative volumes for the same point of view are shown in the 2nd picture).
How can I avoid that?
Is there a better option for blocking at the blade tip?
Thanks in advance!
Last edited by Bollonga; January 29, 2013 at 16:58. Reason: Prefix should be ICEM instead of ansys meshing
Bollonga is offline   Reply With Quote
Old   January 29, 2013, 10:06
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
attach files.
flamejet likes this.
Far is offline   Reply With Quote
Old   January 29, 2013, 13:31
Christoph
energy382 is on a distinguished road
that's not what I would call a sharp trailing edge...
energy382 is offline   Reply With Quote
Old   January 29, 2013, 13:54
Francisco
In the picture the visible edge is the leading edge. The trailing one is on the backward side.
Also, it can be confusing because there's a curve of the same colour as the surface.
But I think that's a sharp edge.
Thanks.
Old   January 30, 2013, 05:06
Francisco
Well, geometry files are not mine so I can't share them until I got permission.
I've realized that negative volumes are not only at the blade tip but in the whole blade surface. I'm gonna try a simpler blocking around the blade and I'll try again.
I'll keep posting.
Old   January 30, 2013, 05:14
Far
Sijal
Like this?
PS: This was not done by me. I guess this master piece was done by Ralen (But I am not sure)
Bollonga likes this.
Old   January 30, 2013, 05:45
Far
Sijal
see this post
http://www.cfd-online.com/Forums/ans...ca0009-3d.html
For 2nd thought
http://www.cfd-online.com/Forums/ans...spinnaker.html
Old   February 11, 2013, 17:33
Francisco
Hi, I'm back with the blade tip blocking after some days off. I've seen Ralen's approach but I have some questions. In the comment #12 of the thread:
http://www.cfd-online.com/Forums/ans...tml#post362126
In step 2 and 3 I don't know exactly in which surface I have to do the o-grid. I guess it's in the selected surfaces in the attached picture, if I am right how do I create an outer o-grid in just that selected surfaces? If I enable around selected blocks the o-grid appears all around the blocks, and not just in the selected surfaces.
Old   February 12, 2013, 04:58
Francisco
I've already solved that, I was just messed up with the o-grid selection.
Old   February 13, 2013, 10:18
Francisco
After several trials I've managed to get some valid blocking for the blade tip following Ralen's approach. See picture 1 before associating vertices
Then I've made all the vertex-point, edge-curve and face-surface associations (picture 2 and 3).
But when I start meshing, there's somethins strange at the tip (see pictures 4 and 5), this has happened to me other times but I don't know how to fix it now. I've checked all associations and they seem all right to me. Why does this happen?
Old   February 13, 2013, 10:36
Francisco
Solved, I just had to move one of the vertex because it was to close to side1 instead of side2.
Old   February 13, 2013, 11:14
Far
Sijal
good...................
Old   February 20, 2013, 04:45
Francisco
I've found a new issue. I've been trying to solve it for a while but I can't find a solution.
The problem is that I want to mesh two parallel edges from a rectangular surface, everything pretty simple (purple surface in picture 1). I've done the associations point-vertex, edge-curve and face-surface. I do the bunching (picture 2), copying to all parallel edges, but it's not meshing properly (picture 3). The two long parallel edges are being mesh just from a concentrated point near the corners (pictures 4 y 5).
What is the cause? What can be the solution?
Thanks a lot!
PS: I don't know if I should open a new thread for this matter, as it is no longer related to the balade tip.
Old   February 20, 2013, 04:47
Far
Sijal
It is the association issue. check associations !
Old   February 20, 2013, 05:10
Francisco
I've checked all associations, even edge to surface ones (picture 1). Everything seem okay. I've done the same for the nearby rectangle and this one has been properly meshed (picture 2).
You think it's a edge to curve association issue of the two long sides?
Old   February 20, 2013, 05:12
Far
Sijal
Yes. It could be edge to curve or vertex to point association problem.
Old   February 20, 2013, 05:25
Francisco
I still don't find the problem. What does the white arrows in previous picture 1 mean? I don't hace those arrows in the other rectangles.
Old   February 20, 2013, 05:35
AB
BrolY will become famous soon enough
Blocking -> Associate -> Update Association.
If it doesn't work, you would have to redo all the association hand by hand.
Your problem sometimes occures if you delete curves or trim surfaces ... It's always better to disassociate a curve (Blocking -> Associate -> Disassociate from geometry -> Edges), and then reassociate.
Good luck
BrolY is offline   Reply With Quote
Old   February 20, 2013, 05:46
Francisco
That solved the problem! Far, you're the man.
Old   February 20, 2013, 08:53
Francisco
I meant Alenxadre, merci beaucoup! Thank you too, Far!
BrolY likes this.
blade tip, hexa mesh, sharp edge, wind turbine
Meshing very thin blade tip Jenny CFX 7 June 27, 2014 08:26
Blade tip with tetra/prism method vinc ANSYS Meshing & Geometry 0 May 17, 2011 15:22
[ICEM] Blocking of impeller single blade sector (MRF) delaneyluke ANSYS Meshing & Geometry 1 May 6, 2011 09:28
[ICEM] Blocking strategy for 1mm tip clearance mr_stoked ANSYS Meshing & Geometry 2 September 21, 2010 15:00
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 13:56
