August 15, 2012, 17:52 |
Meshing 3-D pipe problem
shayan
Hello Dears
I am beginner with Fluent so facing many questions! I plan to create a curved simple 3-d pipe and want to get contours at some sections. 1. Should I make a face at each angle that I need contour? 2. Does each face need special mesh or by meshing the whole volume, no need for meshing the mentioned faces? 3.what about meshing the edges e.g. at inlet? Thank you Last edited by shayan_mv; August 16, 2012 at 04:12. |
August 17, 2012, 13:27 |
brijesh dubey
no,you need not to mesh each face where you want to see your contour.just do the conventional meshing technique like edge mesh then face and then do volume mesh.
In fluent just create plane at the right position and then you can view your contours. |
August 18, 2012, 04:26 |
#3 | |
shayan
But the contours are not logical! I mean at each cross-section the lines are outspread!I think it refers to mesh |
August 18, 2012, 04:43 |
brijesh dubey
ok..then i think you have a mesh problem. if you can send your problem images probably then i can try to provide a better solution for your problem.
August 18, 2012, 04:46 |
shayan
August 18, 2012, 04:55 |
brijesh dubey
ok..check it..all the best
August 18, 2012, 07:37 |
shayan
I meshed my geometry as you suggested,but facing to this error:
6162 nodes. 5700 mixed wall faces, zone 2. 460 mixed pressure-outlet faces, zone 3. 460 mixed velocity-inlet faces, zone 4. Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12. Clearing partially read grid. |
August 18, 2012, 13:33 |
brijesh dubey
your mesh is not good this is the idea i am getting from the problems you are facing.
Do one thing first send me the imges of geometry then i can check and can suggest you some good suggestion. so snd me your geometry image. |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
[Commercial meshers] problem meshing two interacting volumes | banerji | OpenFOAM Meshing & Mesh Conversion | 0 | December 14, 2009 15:59 |
Meshing problem | akr | FLUENT | 2 | February 3, 2008 20:22 |
meshing hollow part of pipe | rai | FLUENT | 0 | December 19, 2005 00:46 |
