[TurboGrid] Help defining Flow Path with external CAD
Old   January 13, 2014, 07:59
Default Help defining Flow Path with external CAD
Oliver Westbrook-Netheton
Ollie West is on a distinguished road
I'm not sure if what I am trying to do 'works' with TurboGrid.
I have a CAD model (SolidWorks - part, not an assembly) of a simplified helicopter rotor head embedded in a wind tunnel section (http://imgur.com/a/0uMPs)
I am trying to use TurboGrid to generate a mesh for the rotor blades so ANSYS can analyse the rotors as they enter vortex ring state (an aerodynamic effect in helicopters).
However, I am having difficulties defining the Flow Path within the geometry section of ANSYS where I have imported the CAD model. When I try to define an Inlet/Hub/Shroud Contour I cannot select a surface.
From research it appears these contours are defined by sketch edges (http://www.sharcnet.ca/Software/Flue...rcreation.html), so it would appear my problem is arising as detail from the CAD model is lost during the import to ANSYS.
Could anyone suggest a way to either:
Import a CAD model to ANSYS whilst keeping all (or a lot of) its detail.
Select contours from an imported CAD model (I have tried using the "Lines from Edges" concept tool etc).
Or have I adopted the wrong approach altogether for what I am trying to achieve?
Ollie West is offline   Reply With Quote
cad model, flow path, turbogrid
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Modeling internal and external flow for a nozzle smschnob Main CFD Forum 1 November 11, 2010 17:12
Domain for external flow chinc Main CFD Forum 2 August 8, 2010 01:23
Best settings for solar car external flow problems kdrbrk Main CFD Forum 0 July 16, 2010 02:18
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
