[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts
Like Tree3Likes
  • 1 Post By mrk
  • 1 Post By PSYMN
  • 1 Post By mrk
Old   September 26, 2012, 04:30
Default Generating mesh for modified parts in ICEM without changing mesh of other parts
ALI
a.habibi is on a distinguished road
Dear Friends,
As a person who is new in CFX and ICEM, I am wondering how can I generate mesh for modified parts in ICEM without changing mesh of other parts?
Indeed, I am working on heat transfer modelling of a room that has already been meshed with ICEM and solved by CFX setup by another person. What I am want to do is to modify the room by adding some walls and just producing mesh for those walls and re-solve the problem by the aid of available mesh and defined boundary condition in CFX setup.
I created those walls and mesh them (QUAD_4) without changing available mesh of geometry with difficulties (I did not find any specific tutorials in this regard). But, when I import ICEM into the CFX setup, I can not see those walls! Now, I am confused where is problem
1- Is it about the way that I mesh those walls? (ICEM shows that they are meshed with QUAD_4) ---> I am more suspicious about this since I did not find any specific tutorials in this regard and mesh those walls with difficulties.
2- Whether problem is in importing ICEM to CFX setup?
3- Or, this is not the way to mesh just those walls, and I should do something else.
Please guide me, I am totally confused.
a.habibi is offline   Reply With Quote
Old   September 26, 2012, 04:52
Christoph
energy382 is on a distinguished road
Originally Posted by a.habibi View Post
Dear Friends,
what kind of mesh does already exist?! hexa?
there are many several ways to do:
In my opinion, the easiest way to do is to modify your cad-geometry, load your existing blocking and do some additional splits around the new walls.
some more details or pics would really help
energy382 is offline   Reply With Quote
Old   September 28, 2012, 11:21
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Christoph is right about hexa... Just load the new geometry with the old blocking file and make the splits and associations that you need to the blocking file... Assuming your walls are just zero thickness baffles, you will need to split and then associate the new face to the surface... If they have thickness, you will need to split and then delete the block within the wall (or put it into a wall material).
If you have a tetra mesh, you can mesh with quad or tri, import the mesh and then use "make consistent" to get the volume tetras to align and become conformal with the new surfaces...
However, if you have a tetra prism mesh, you will find that it is easier to add the geometry and then just push the button to remesh it...
All of this is easier if you can get the ICEM CFD files from your colleague, but you can extract the geometry and blocking from a mesh file if you need to.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   October 1, 2012, 09:10
Default Icem cfd
mrk
mark
mrk is an unknown quantity at this point
Dear friends,
i am new to ICEM cfd i have my cad Diagram in IGES format, i want to do external analysis, i create outer domain and i want to subtract my cad model,with outer domain, how i can do this? please help me
amin_gls likes this.
mrk is offline   Reply With Quote
Old   October 1, 2012, 10:17
PSYMN's Avatar
Simon Pereira
In ICEM CFD, you don't need to do any subtraction or anything like that. It is a surface based modeler. Just mesh it.
If you don't want mesh inside your model, create a material point between the geometry and the enclosure...
Try a tutorial or two.
Old   October 4, 2012, 05:10
Default ICEM CFD doubt
mrk
mark
thanks Simon, sorry for late , i have cube enclosed by bigger cube, i want to subtract from bigger cube to smaller cube, then i want to make tet mesh externally, how i can do this in ICEM CFD, i don't want mesh inside cube, i want mesh only subtracted area of bigger volume, i don't want to use blocking concept, i want only tet mesh please help me
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Unstructured Mesh ICEM on a cube jerome_ ANSYS 0 May 30, 2012 05:34
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
