[DesignModeler] Importing Solidworks body (incl parameters) into DesignModeler
Old   April 14, 2013, 08:01
Default Importing Solidworks body (incl parameters) into DesignModeler
Evona is on a distinguished road
Hi there!
I am having trouble getting DesignModeler to carry over the Global Parameters from a Solidworks body.
I have accomplished this well enough using NX 7 in the past but for some reason it won't work this time around with a Solidworks CAD file.
From what I understand, the Solidworks Global Variables must be named in such a way (with a double capital letter prefix):
Then, using the Add-on:
The Geometry file is liked to ANSYS Workbench and set into a Geometry Component:
Opening DesignModeler presents this screen:
The highlighted line in the previous image ('Basic Geometry Options' - 'Parameter Key') is default at "DS" so this needs to be changed to "ES" so DesignModeler can detect the parameters in the Solidworks geometry file.
This is where the problem is.
The geometry is imported perfectly but the Global Parameters are not :/
I tried changing the Solidworks Global Parameters to "DS" and even that didn't help.
Any ideas?
Evona is offline   Reply With Quote
geometry import, parameters, solidworks.
Importing SolidWorks Model DIRECTLY into openfoam bgood44 OpenFOAM 9 January 20, 2020 06:47
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Importing Rhinoceros 3d model to SolidWorks george85 FloEFD, FloWorks & FloTHERM 21 March 5, 2014 05:19
[DesignModeler] Sketching from entities in an imported body (SolidWorks Interface) t_clark ANSYS Meshing & Geometry 2 January 30, 2014 06:21
Problem importing solidworks to gambit holyo ANSYS Meshing & Geometry 3 April 16, 2010 05:16
