[Workbench] Meshing 2D
Old   April 17, 2013, 21:55
Default Meshing 2D
Francis
francis1 is on a distinguished road
From the attachment, I face some problem in meshing the top part of the channel. I am interested in meshing 2D, thus I would like to mesh the top part of the channel as a single rectangular cell instead of a rectangular cell containing two triangles, as shown from the attachment. Any help on this is much appreciated. Thanks and looking forward to your response.
Cheers
Francis
francis1 is offline   Reply With Quote
Old   April 18, 2013, 05:22
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Look into sweep meshing. One element in sweep direction
jrunsten is offline   Reply With Quote
Old   April 18, 2013, 07:26
Francis
Thanks for the reply. I am also interested to apply inflation near the wall. The sweep method seems not compatible with inflation method, may I know is there any alternative way to do it?
Old   April 18, 2013, 07:28
Josef Runsten
Right click on the sweep method and choose "inflate this method".
When sweeping you inflate a face from an edge, then sweep that face through the body. This is not the same as other methods where you inflate a body by selecting the wall surfaces.
Old   April 19, 2013, 08:06
tita
ok___ko is on a distinguished road
Hi, could you explain why we need block after drawing the geometry, before the mesh? Thanks
ok___ko is offline   Reply With Quote
Old   April 19, 2013, 17:08
Far
Sijal
Blocking means you are subdividing your volume into smaller blocks which can be mapped mesh.
Old   April 19, 2013, 17:11
tita
OK. Thank you for your reply.
Old   April 20, 2013, 07:15
Francis
Thank Josef!
Old   April 20, 2013, 10:34
Default after pre-mesh in ICEM
tita
I met a problem after I finish my mesh. After I pre-mesh it, and I 'loading from block', in the command window, it says
'Unloaded unstructured domain
--- Unloading existing mesh
Loading domain "hex.uns" ...
domain has 0 nodes'
Does anyone know why, and where I have made the mistake? I am looking forward to your reply. Thank you.
Old   April 20, 2013, 10:42
Far
Sijal
Right click on premesh and choose option "convert to unstructured mesh"
tita I would suggest you to open new thread on your problem.
Old   April 20, 2013, 11:02
tita
well, I am sorry for that, I am new here, but I know how to open new thread now.
And thanks for your answer,it has nodes now, but hexas=0, and I cannot import the mesh into FLUENT, and in the fluent command, it says 'Error: Null Domain Pointer'.
Do you know why?
Old   April 20, 2013, 11:04
Far
Sijal
It is 2d case? Did you choose 2d option while exporting mesh? are you opening this mesh in 2d version of Fluent?
Old   April 20, 2013, 11:18
tita
yes, I have already choose 2D in the FLUENT. But it still cannot be imported.
Old   September 7, 2013, 05:44
efe
knotbhp is on a distinguished road
hi everybody,
could you inform detailly about sweep mesh ?,and also when apply inflation layer, skewness increases, what do i do now?
thanks.
knotbhp is offline   Reply With Quote
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
