[ICEM] Extrude mesh
Old   June 25, 2013, 07:21
Smile Extrude mesh
Luis
luissanchez is on a distinguished road
Hi all, tanks for this forum.
Im new in ICEM-CFD. I want to mesh a bodie with same mesh between faces.
I try to do a 2d mesh in one faces and modify this until its prepared, but my problem comes i dont know how i can do this 2d mesh to a 3d mesh in the bodie. I try to extrude this mesh( into the edit mesh tab) but the elements come out.
Tanks for the help.
luissanchez is offline   Reply With Quote
Old   June 25, 2013, 08:08
kad
kad will become famous soon enoughkad will become famous soon enough
Probably you are extruding with a fixed spacing, which is larger than your geometries thickness. Try the method "extrude along curve" and set bunching params on the extrude curve before. Also see the icem manual for further information.
kad is offline   Reply With Quote
Old   June 25, 2013, 08:22
Javi
FJSJ is on a distinguished road
Hi luissanchez,
I think you are using tools wrong. If you want to get the same mesh in 2 surfaces, try to make a 3D blocking. This example itīs not difficult. Or... you can try with 2D planar blocking and then extrude it with Blocking -> Create Blcok -> 2D to 3D
Then you can use, Extrude Mesh, under Edit Mesh bar. Personally, Iīve never tried but maybe in your case It can be well.
FJSJ is offline   Reply With Quote
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
ICEM extrude mesh by rotation derkaiser ANSYS 0 December 21, 2009 05:01
