[ICEM] Could you please have a look at my airfoil mesh?Thanks |
September 11, 2013, 08:08 |
Rep Power: 12 |
Hi guys.
This is a 2D airfoil mesh I'm using in CFX. However, the simulation result is not so acccurate. And I wanna check if the mesh contributes to the error. Here is it. I'm using k-omega SST, the Yplus equals 0.2, which is Ok. The orthogonal quality, determiant, angle, as you see, is fine. Well, I have the following problems: 1) The aspect ratios. The ARs around the airfoil surface are all below 6000. But a large number of cells extending from the trailing edge have high ARs. It seems that this cannot be eliminated if you wanna set the distance from the first cell to the wall quite small, can it? 2)I saw someone say the rule of thumb is that aournd the airfoil ARs even could have a maximum value of 10000, but high ARs should be got rid of in the far field. Are they correct? So how about those high AR cells in my grid, do they impact on the result? Any improvement I can do? Thank you in advance. |
September 11, 2013, 08:10 |
Rep Power: 12 |
Here is more.
September 11, 2013, 08:16 |
Rep Power: 12 |
By the way, problem 3: What are those redundant cells outside the domain shown in picture 5?
September 11, 2013, 09:28 |
Stuart
Rep Power: 25 |
I assume you know that CFX cannot solve 2D simulations. Have you extruded the mesh so that it is 1 element thick?
September 11, 2013, 09:41 |
#5 | |
Rep Power: 12 |
More specificly, I extrude it with one element whose spacing equals the same order of the smallest length scale of the elements, which in my case is 0.001mm. |
September 11, 2013, 11:50 |
Stuart
Rep Power: 25 |
High aspect ratio elements extending downstream from the sharp trailing edge are an unfortunate outcome of a C-grid like this. What about changing to an O-grid instead (e.g. http://www.grc.nasa.gov/WWW/5810/rvc/grape/GK-xyz.png) if you don't like those high AR elements.
Did you see PSYMN's youtube videos for this geometry (https://www.youtube.com/watch?v=tYrbScUH9RE)? High AR elements are ok in the boundary layer and the CFX guide (cannot remember where exactly) says something like 10^6 is ok. What's the Reynolds number, Mach number and angle of attack? Are you running CFX in double precision mode? Are you using the High Resolution advection scheme? |
September 11, 2013, 13:23 |
Export it as Fluent mesh and import into CFX. It will automatically extrude it by one element.
September 11, 2013, 13:26 |
#8 | ||
You can open up mesh in the farfield. |
September 11, 2013, 21:52 |
#9 | |
Rep Power: 12 |
I haven't tried a O-grid, maybe I can give it a shot. Since many literature claim they are successful in utilizing C-grid for this S809 airfoil. Well, bad news is that Youtube is blocked here, good news is that here is not DPRK. If you refer to Mr.Simon Pereira's tutorial(3 parts) on airfoil meshing, I'm lucky enough to have gone it through. My grid is following his tutorial. In my case, Re=2*10^6, AOA=1.02, I've tried both incompressible and compressible condition, the difference of the results are negligible, since the Mach number ranges from 0 to 0.199 in the compressible case, so I just regard the low-speed flow as incompressible. Yes, with double precision and high resolution advection scheme. Well, my Cl=0.24<0.27,Cd=0.14>0.07, the latter are experimental results. I can show you the Cp by the way. |
September 11, 2013, 21:58 |
#10 | |
Rep Power: 12 |
Someone mentioned this in this forum. What do you mean by saying "You can open up mesh in the farfield" exactly? I don't understand. Thank you. |
September 13, 2013, 14:30 |
#11 | |
By the way, I can see from picture 8 in the post #2 that you are not imposing a smooth change in cell size. I mean that it appears that the size from the cells at the trailing edge change too abruptly to a significant small cell immediately downstream. I hope I explained myself well enough. Regards, César |
Low Speed Airfoil | Mancusi | FLUENT | 7 | April 3, 2014 06:11 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
[GAMBIT] Meshing airfoil using .dat file problem | creggie | ANSYS Meshing & Geometry | 10 | June 27, 2010 19:24 |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 11:31 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
