[ICEM] [icem] split geometry to mesh
Old   September 26, 2013, 01:03
Default [icem] split geometry to mesh
liuyan
blgypeng is on a distinguished road
Hello everybody,
I am new to the forum and just started entering the field of CFD. Please be patient with me
For my bachelor thesis I will be working with the CFD study of a Wind Turbine.
i use icem cfd to mesh structure grid .now i have two ways to mesh.
1 one geometry split to sub-geometry ,and mesh individually.
2 use multiblock to mesh .
my questions is :when i use multiblock to mesh how to do in the interface .because the parameters of edge belong two block is not equal in the interface.
or in the first way ,how to meger the sub-mesh for a entire mesh .i found that separate to mesh ,the quality is high ,may be i have not find correct block .
who can heip me solve the promble ?
may be i not speak clearly .this is 3 piture.
Thank you for your attention.
blgypeng is offline   Reply With Quote
Old   October 2, 2013, 04:28
Javi
FJSJ is on a distinguished road
First of all, what is your domain? The mesh that appear in these pictures is refered to your complete domain? If I were you, firstly I try to get a blocking of all your geometry (including the blade). If you donīt get it try to define a subdomain near blade and other one with the rest of domain.
FJSJ is offline   Reply With Quote
Old   October 2, 2013, 14:43
AhmadReza
ahmadreza is on a distinguished road
Hi
You must avoid to make triangle block
you must make small block near the hub and make to square block above it
you must show your geometry with mesh not just show your mesh !!!!1
ahmadreza is offline   Reply With Quote
Old   October 5, 2013, 00:05
liuyan
FJSJ, thank u for your reply. As you said,I try to get a blocking of all geometry (including the blade) and sucessed to mesh geometry. output the mesh,input the mesh to fluent and check,appear a message is "WARNING: Unassigned interface zone detected for interface 22;WARNING: Unassigned interface zone detected for interface 23;WARNING: Unassigned interface zone detected for interface 24."
I guess the problem also is interface,and check the mesh in icem,found the interface between the block has two layer face mesh. The left interface side of the block is Y block.Maybe the problem was caused by Y block. icem
the block and geometry file :http://pan.baidu.com/s/19Umag In accordance with the picture to download the file.
please help me look the problem.
waiting for your suggestions.
Old   October 5, 2013, 01:52
Far
Sijal
The way you made interface and blocking is not a good idea, specially at the blade tip. Make continuous blocking...
Old   October 5, 2013, 10:11
liuyan
thank you suggestion, now i make a continuous blocking,but i have a problem,when i use Y block to split triangle geomtrey,at the same time,the original interface has change,Or between the block generate the interface.so,i dont know how to do.
icem, interface, merge mesh
[ICEM] Create geometry (iges or step file) from fluent mesh muketa ANSYS Meshing & Geometry 10 August 5, 2015 05:38
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 09:14
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
