[GAMBIT] Very thin annular space.
Old   October 8, 2013, 08:31
Default Very thin annular space.
prince
prince_pahariaa is on a distinguished road
Dear Friends
I am facing difficulty in meshing. Details of geometry is like this
1) There is cylinder of diameter 154 mm of length 90 mm.
2) With this cylinder, an annuls cylinder of length 203 mm (of diameter 154 mm and 153.8 mm) is attached. So the annulur space is very less (0.1 mm) through which flow occurs.
3) There is small horizontal pipe which is attached to cylinder (point 1) from where inlet of gas is provided into cylinder. diameter of small horizontal pipe is 6.264 mm)
I am not able to mesh this geometry may be because of very small annular space. I am looking in any guidance how to mesh it properly.
Looking forward for any help
prince_pahariaa is offline   Reply With Quote
Old   October 9, 2013, 00:43
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post pictures describing your point 3
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[ICEM] airflow in an annular space between outer and inner pipe malay ANSYS Meshing & Geometry 23 February 28, 2013 12:58
How to model the NR eqns in a domain with empty space Vasilis Main CFD Forum 1 April 14, 2009 04:35
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Thin surfaces within a body using DesignModeler? Forrest CFX 7 April 5, 2005 08:21
Modelling thin surfaces in 5.6 Louwrens CFX 0 August 16, 2003 10:47
