[ICEM] blocks with different mesh types
Like Tree15Likes
Old   July 6, 2016, 07:20
Default blocks with different mesh types
Daniel
Daniel_Khazaei will become famous soon enough
Hello guys
Is it possible to get a mesh like this in ICEM CFD?
if it's feasible, would you please kindly tell me how can I do it...
tnx in advance
regards
Daniel_Khazaei is offline   Reply With Quote
Old   July 6, 2016, 07:27
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
yes. It is hybrid mesh.
Send your goemetry
Daniel_Khazaei likes this.
Far is offline   Reply With Quote
Old   July 6, 2016, 08:33
Daniel
Send your goemetry
tnx for the quick reply
here is the geometry
Old   July 6, 2016, 09:49
Far
Sijal
geometry is different than the pics you have shown
Old   July 6, 2016, 09:59
Daniel
yes, the picture is from fluent tutorial, but I want to create a mesh similar to the picture!
unstructured near the hull and structured in far-field! like this one:
Can you tell me how can I do conformal unstructured+structured mesh?
tnx
Old   July 6, 2016, 12:37
Daniel
just tried ICEM CFD tutorial and I learned how to do it, here is the initial try:
Old   July 6, 2016, 12:44
Far
Sijal
you are on right track
Old   July 6, 2016, 17:49
Daniel
is there anyway to have a uniform surface mesh for the hull surface?
as you can see the mesh is distorted near the curve...
Old   July 6, 2016, 18:03
Far
Sijal
I dont get these problems
Old   July 6, 2016, 18:15
Far
Sijal
https://www.youtube.com/watch?v=fH-E...4azq1gbyqsrk0k
Old   July 6, 2016, 21:25
Daniel
thank you very much!!
Now everything is perfect...here is the final mesh:
Fluent Max Skew: 0.59
Min Orthogonal Quality: 0.32
Far likes this.
Old   July 7, 2016, 06:17
Far
Sijal
Part II is underway where whole process is explained.
would you like to share your process with files?
Old   July 7, 2016, 09:08
Daniel
you mean sharing the project files?
Old   July 7, 2016, 09:10
Far
Sijal
yes if you like. and also steps you have followed
Old   July 7, 2016, 09:30
Daniel
As I think you have already noticed, the final picture is from another geometry! I don't have the permission to share the geometry itself...
However I can provide step by step tutorial of the project with pictures, if it's OK without sharing the geometry itself
Old   July 7, 2016, 09:31
Far
Sijal
yeah sure np. Steps will be good for others who will seet his thread in future
Old   July 8, 2016, 07:30
Daniel
1) At first I have created the domain around the hull in such a way to have a smaller box near the hull (unstructured) and a larger box away (structured):
Note, you should have interface between smaller and larger boxes!
2) then I created a material point in the smaller box by selecting point 1 and 2:
3) Now the mesh sizing is defined.
4) Then I generate the mesh for the the smaller box. It's better to check the mesh quality for any errors at this step.
5) Now save the project and disable mesh in display tree! you can also save the mesh manually if you want!
6) Now start the usual blocking approach for the structured part! the important part is to delete the block where you have already meshed with tetra.
7) After you are done with blocking, update the mesh sizing and edge refinement in pre-mesh params!
8) Now enable the pre-mesh in display tree to have your hexa mesh generated! check if everything is as expected!
9) save the blocking and disable prem-mesh in display tree!
10) enable mesh in display tree and go to file> Mesh > load from blocking!
click merge when the pop up opens!
11) Now both meshes are merged, but there is one more step to make them conformal.
go to mesh> merge nodes > merge meshes!
method: merge volume meshes
merge surface mesh part: here select the interface between two boxes!
before:
after:
it's done!
metmet and attiquejavaid08 like this.
Old   July 8, 2016, 16:53
Far
Sijal
Very nice write up. Excellent work.
Thankyou.
Old   July 8, 2016, 22:18
Daniel
Thankyou.
@Far
Would you please help me with this:
http://www.cfd-online.com/Forums/flu...ot-remesh.html
Old   July 12, 2016, 09:28
Daniel
Thankyou.
Is it possible to create and smooth the surface mesh on the hull, then use the surface mesh to generate the prism+tertra volume mesh?
I have done the patch dependent surface meshing, but always get error when trying to use the surface mesh in octree or delaunay?
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[mesh manipulation] Combining multiple mesh blocks ingojahn OpenFOAM Meshing & Mesh Conversion 1 August 18, 2014 03:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
