[ANSYS Meshing] Meshing problems
Like Tree1Likes
  • 1 Post By i-torch
Old   April 7, 2014, 20:08
Default Meshing problems
Alexander
i-torch is on a distinguished road
Hello everyone. Sorry for a bad english, but i try to explain my problem.
I am meshing journal bearing with oil inlet, and all of my attemps unsuccessful.
I had to slice the geometry because of poor mesh quality.
1-thin film
2-inlet pipe
and now i have a problem with connection of 2 fluid zones
I tryed recomendations from this thead but it doesn't help
http://www.cfd-online.com/Forums/flu...tml#post278469
Could you tell me what i should to do. Maybe i have missed something important.
Catabay likes this.
i-torch is offline   Reply With Quote
Old   April 9, 2014, 02:20
Bharath kumar
bharath is on a distinguished road
your problem description wasn't clear.
Please upload your case file if possible.
bharath is offline   Reply With Quote
Old   April 9, 2014, 03:32
Thumbs up
praveen@cfd-online.com's Avatar
Praveen Kumar R
praveen@cfd-online.com is on a distinguished road
Hi Aleaxander,
If I am not wrong, you have created two separate volume meshes for thin-film & inlet-pipe and trying to define a non-conformal interface between the two volume meshes/zones.
What is the problem you are facing in defining the non-conformal interface. Does Fluent gives some error message? Or you don't see fluid flowing from inlet pipe into thin film region?
Having said that, creating a single connected / conformal mesh is possible for your case, if you are using Multi-block approach.
Happy Learning!!!
Praveen Kumar R
praveen@cfd-online.com is offline   Reply With Quote
Old   April 9, 2014, 05:53
Alexander
Case file
There is no any error message from fluent. I see it by the pathlines. Fluid doesn't flow from inlet into film region. Sometimes it look like in attach.
I have changed the geometry.
Mesh
Old   April 9, 2014, 07:53
Thumbs up
Praveen Kumar R
Hi Aleaxander,
I examined the case file, the interface looks just fine.
When tried to run the case setup as it is, I observed a pathline similar to what you got. i.e., flow not going from inlet zone to film zone.
But I was not sure whether the issue is with interface or not. So, I tried running the case with velocity inlet (0.25 m/s randomly taken this value) and its working fine. Please see the attached picture.
As I said, the interface looks just fine. Please revisit pressure values at the boundaries....
All d best!!!
Happy Learning!!!
Praveen Kumar R
Old   April 9, 2014, 10:27
Alexander
Thank you!!! I could not imagine what the problem is. Using velocity-inlet boundary instead pressure-inlet helps. It is interesting why this is happening.
I will try to improve my model so maybe there where any questions=)
[GAMBIT] Problems while meshing a 3d CAD model CFDST ANSYS Meshing & Geometry 28 January 7, 2013 01:52
[ICEM] Problems with meshing of wind turbine Dosis ANSYS Meshing & Geometry 14 November 13, 2012 05:41
Problems of Icem meshing about Conical Forebody raja2010 ANSYS Meshing & Geometry 2 December 6, 2010 09:20
[snappyHexMesh] Problems meshing a pipe U.Golling OpenFOAM Meshing & Mesh Conversion 2 November 30, 2010 05:24
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
