[ICEM] Meshing a T in both 2-D and 3-D
Old   April 28, 2014, 20:35
Default [ICEM] Meshing a T in both 2-D and 3-D
Ifyi is on a distinguished road
Hello people. I am using ICEM to mesh a T in both 2-D and 3-D. I am required to make the centre and close to the egdes more dense. I actually could do the one of the edges using the ratio and spacing functions but that of the centre remains an issue for me. please I need assistance. Kindly advice how to do this if you can or have any suggestions.
Sorry I was trying to start a new thread. How do I start a new thread. It will be same question though. Thanks
Ifyi is offline   Reply With Quote
Old   April 30, 2014, 14:02
Retired Super Moderator
Bruno Santos
I've moved your question to a new thread on the correct sub-forum.
If you have questions on how to use the forum, check the FAQ link at the top of the page. For example, for creating new threads, it's explained here: http://www.cfd-online.com/Forums/faq..._threads_posts
Old   May 1, 2014, 06:30
Please I am still waiting for a possible solution. Thanks
Old   May 1, 2014, 06:59
Daniel Frederik
Daniel Frederik is on a distinguished road
What do you mean by "the centre and close to the egdes "?
You want more density in the center of the T and on the edges?
Daniel Frederik is offline   Reply With Quote
Old   May 1, 2014, 08:37
Daniel Frederik
with this function marked in the picture yellow you can choose points around the zone you want to have more density.
Old   May 1, 2014, 12:16
Thanks Daniel. I will try to use them once more. My school is closed for the holiday so I will get back to you next week Monday. Thanks once again
Old   May 7, 2014, 06:13
I have tried that and it did not work. The one I have problem with is make the centre to be more dense. I am able to do the one of the edges through the blocking strategy pre mesh functions.
Please anyone who can help should please.
Old   May 7, 2014, 09:46
Daniel Frederik
with that simbole i market up there in the picture you are able to select several points around the zone you want to have more density... did you see that?
Old   May 7, 2014, 09:47
Daniel Frederik
ah in the first place what kinda mesh you want? hexa or tetra?
Old   May 7, 2014, 14:57
Hexa. Do i have to make a point at the centre? I mean a point at one end and another at the other end?
Old   May 9, 2014, 10:59
Daniel Frederik
a screenshot of your geometry would be helpful its a little hard to know what you exactly want
[ICEM] Meshing Error with a Solidworks Geometry Fractal ANSYS Meshing & Geometry 2 November 12, 2019 12:59
[ICEM] Problems with meshing in ICEM CFD Benne ANSYS Meshing & Geometry 2 September 17, 2012 03:08
[ICEM] Meshing a centrifugal compressor impeller Mitpostdoc ANSYS Meshing & Geometry 8 February 25, 2011 10:51
Basic steps meshing an airfoil [ICEM] peterputer111 ANSYS Meshing & Geometry 4 April 19, 2010 12:08
