[ICEM] 3D Orifice plate with pipe Blocking + Meshing |
June 3, 2014, 21:57 |
Kartik
Rep Power: 12 |
Hi guys,
I've been trying to mesh the geometry attached. I created the geometry using DesignModeler and imported it into ANSYS ICEM using the workbench reader function. I then created three blocks for the three different sections (Inlet cylinder, Orifice and outlet cylinder) (screenshots attached). I then created the ogrid blocks and set the mesh parameters. The problem is that the pre-mesh for the inlet and outlet cylinder seems to be fine but the mesh at the orifice itself seems to large and unstructured. I'd ideally like the mesh to be similar to the screenshot of the outlet. Any help/suggestions in this regards are appreciated. Thanks in advance. Edit: I've also added the geometry and blocking file if anyone is interested. https://drive.google.com/file/d/0BwJ...it?usp=sharing https://drive.google.com/file/d/0BwJ...it?usp=sharing Last edited by kyaj001; June 4, 2014 at 22:37. Reason: Editing file link |
June 21, 2014, 02:37 |
Kartik
Rep Power: 12 |
Hi everyone,
So i managed to solve this little issue. Found out that it had to do with the way i was blocking the geometry. If anyone else is interested in a situation similar to this, this post was very helpful: http://www.cfd-online.com/Forums/ans...diameters.html Thanks again |
3d orifice plate, blocking, icem, meshing |
[ICEM] ICEM PIPE bend meshing | firavia | ANSYS Meshing & Geometry | 3 | December 23, 2012 09:29 |
[ICEM] Hexa meshing blocking problem | fergal | ANSYS Meshing & Geometry | 0 | June 28, 2011 10:01 |
+ shape circular pipe - meshing possible? | Selina Tracy | Main CFD Forum | 2 | January 16, 2003 13:31 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
