June 16, 2014, 13:30 |
opening between the two zones
hassanmaleki
Rep Power: 11 |
Hi
I want to create an opening between the two zones. according to the pictures; I'm using a pseudo volume to subtract opening surface from both zones but fluent can not discern this opening and no airflow across from the opening!! Do you have any idea? Best regards, Hassan |
June 17, 2014, 00:28 |
Maxime Perelli
Rep Power: 41 |
Can you sketch what you want exactly to compute.
And explain exactly what you did
In memory of my friend Hervé: CFD engineer & freerider |
June 17, 2014, 03:43 |
hassanmaleki
Rep Power: 11 |
Hi again
Firstly, thank you for your attention! I want to simulate the airflow between two rooms and these rooms are connected through an opening on the wall that is shared by two rooms! ( according to the sketch). I'm modeling my Geometry in gambit according to my last post and import the mesh into fluent! in iteration process I checked velocity vectors and was seeing that no airflow across from room1 to room2!!! and fluent can not discern this opening! so,I think my modeling process in gambit is wrong! Do yo have any idea for create this opening between two rooms in gambit? Best regards, Hassan |
June 17, 2014, 04:04 |
Maxime Perelli
Rep Power: 41 |
Then I would build your wall with the opening as solid for finally split it from the fluid domain:
June 17, 2014, 04:23 |
hassanmaleki
Rep Power: 11 |
Thank you
I will try your solution! |
Skipping Zones | 1337Hal | FLUENT | 1 | June 27, 2022 09:33 |
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 18:00 |
Comsol - Opening valve | denismaloir | COMSOL | 0 | May 4, 2012 06:49 |
opening sims as a wall. | Curran919 | CFX | 8 | March 19, 2012 21:31 |
Help setting up pressure function across opening | Jenny | CFX | 3 | October 18, 2007 00:16 |
