[GAMBIT] opening between the two zones
Old   June 16, 2014, 13:30
Smile opening between the two zones
hassanmaleki
hassanmaleki is on a distinguished road
Hi
I want to create an opening between the two zones. according to the pictures; I'm using a pseudo volume to subtract opening surface from both zones but fluent can not discern this opening and no airflow across from the opening!!
Do you have any idea?
Best regards,
Hassan
hassanmaleki is offline   Reply With Quote
Old   June 17, 2014, 00:28
-mAx-'s Avatar
Maxime Perelli
Can you sketch what you want exactly to compute.
And explain exactly what you did
Old   June 17, 2014, 03:43
hassanmaleki
Hi again
Firstly, thank you for your attention!
I want to simulate the airflow between two rooms and these rooms are connected through an opening on the wall that is shared by two rooms! ( according to the sketch).
I'm modeling my Geometry in gambit according to my last post and import the mesh into fluent! in iteration process I checked velocity vectors and was seeing that no airflow across from room1 to room2!!! and fluent can not discern this opening!
so,I think my modeling process in gambit is wrong!
Do yo have any idea for create this opening between two rooms in gambit?
Best regards,
Hassan
Old   June 17, 2014, 04:04
-mAx-'s Avatar
Maxime Perelli
Then I would build your wall with the opening as solid for finally split it from the fluid domain:
Old   June 17, 2014, 04:23
hassanmaleki
Thank you
I will try your solution!
Skipping Zones 1337Hal FLUENT 1 June 27, 2022 09:33
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Comsol - Opening valve denismaloir COMSOL 0 May 4, 2012 06:49
opening sims as a wall. Curran919 CFX 8 March 19, 2012 21:31
Help setting up pressure function across opening Jenny CFX 3 October 18, 2007 00:16
