[ICEM] Periodic grid for wedge-shaped geom into FLUENT
Old   September 8, 2014, 10:14
Default Periodic grid for wedge-shaped geom into FLUENT
windhair's Avatar
windhair is on a distinguished road
Dear all
I try to generate grid for such wedge-shape geometry, solve it in FLUENT. In order to solve it more quickly, 1/6 of the geometry is applied, and periodic zone is used.
Define the parts as
Define the periodic block as
But in FLUENT, I got such error as:
> Reading "D:\Test\fluent.msh"...
Clearing partially read grid.
9261 nodes.
8000 hexahedral cells, zone 8.
22800 quadrilateral interior faces, zone 9.
400 quadrilateral wall faces, zone 10.
800 quadrilateral wall faces, zone 11.
400 quadrilateral velocity-inlet faces, zone 12.
400 quadrilateral pressure-outlet faces, zone 13.
Building...
mesh
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
What is the problem?
Thanks
windhair is offline   Reply With Quote
Old   September 8, 2014, 14:51
Sebastian Engel
bluebase will become famous soon enough
After defining the periodicity in the global mesh setup, did you connect the corresponding vertices with perodicity?
When the global Periodicity is set, every vertex in the periodic face needs to be connected to its counterpart in the other periodic face. The program feature can be find in blocking>edit block>periodic vertices
bluebase is offline   Reply With Quote
Old   September 10, 2014, 13:11
windhair's Avatar
Thanks, solved it. missed one step .
periodic boundaries in Fluent littlelz FLUENT 1 March 25, 2014 05:08
[ANSYS Meshing] uniform grid in Fluent Jim87 ANSYS Meshing & Geometry 0 May 7, 2013 17:00
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 14:46
[Commercial meshers] Exporting from V grid to fluent, .msh format Karl SG OpenFOAM Meshing & Mesh Conversion 0 April 14, 2013 23:33
[Commercial meshers] fluent patch type periodic not recognised although no periodics are defined Bando OpenFOAM Meshing & Mesh Conversion 4 December 4, 2012 14:06
