[ICEM] Meshing a pipe with sudden expansion
Like Tree2Likes
  • 1 Post By pbalz
  • 1 Post By diamondx
Old   March 14, 2015, 15:59
Post Meshing a pipe with sudden expansion
Farzin
FarzinD is on a distinguished road
I'm trying to generate a structured grid on a pipe with sudden expansion, using ICEM CFD.
I tried many methods to do that, though I'm new to ICEM.
One of those is to split the block in three part, delete the middle one and associate others individually to pipes with different diameters. Then using O-Grid block split. By doing so I got a bad mesh quality on the expansion area.
Another idea was to keep the middle block after the split. It would be a 2D-like block, on the expansion plane. This time I got a little better quality but still not sufficient, on the expansion plane.
Here is the mesh quality statistics using the later procedure:
0 -> 0.05 : 301 (1.276%)
0.05 -> 0.1 : 0 (0.000%)
0.1 -> 0.15 : 0 (0.000%)
0.15 -> 0.2 : 0 (0.000%)
0.2 -> 0.25 : 0 (0.000%)
0.25 -> 0.3 : 0 (0.000%)
0.3 -> 0.35 : 0 (0.000%)
0.35 -> 0.4 : 0 (0.000%)
0.4 -> 0.45 : 0 (0.000%)
0.45 -> 0.5 : 0 (0.000%)
0.5 -> 0.55 : 0 (0.000%)
0.55 -> 0.6 : 744 (3.153%)
0.6 -> 0.65 : 246 (1.043%)
0.65 -> 0.7 : 1330 (5.636%)
0.7 -> 0.75 : 2244 (9.510%)
0.75 -> 0.8 : 4188 (17.748%)
0.8 -> 0.85 : 4866 (20.621%)
0.85 -> 0.9 : 3046 (12.908%)
0.9 -> 0.95 : 1768 (7.492%)
0.95 -> 1 : 4864 (20.613%)
And these are figures of the pipe and grid.
Any suggestion would be appreciated,
Farzin
FarzinD is offline   Reply With Quote
Old   March 16, 2015, 14:54
Pascal Balz
pbalz is on a distinguished road
I'm not sure if I understood you correctly.
But here's how I would mesh this geometry:
1. Create ONE block for the whole geometry
2. Do a O-Grid Split on the whole block
3. Do another O-Grid Split on the newly created middle block
4. Split all blocks at the expansion edge
5. delete the four outer blocks at the small cylinder
6. Assign edges to your geometry
FarzinD likes this.
Regards,
Pascal
pbalz is offline   Reply With Quote
Old   March 16, 2015, 14:55
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
start by blocking without including the expansion. then extrude the face... easy like that
FarzinD likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 16, 2015, 16:40
Smile
Farzin
Originally Posted by pbalz View Post
Thank you;
I did it as you suggested and it ended with a good quality of mesh on the expansion plane.
Old   March 21, 2015, 14:58
Post
Farzin
Now I'm trying to do an unstructured mesh on half pipe expansion. I do it in similar way I did pipe expansion.
It gives a good mesh quality, but when I import it in ANSYS CFX, solver says the symmetry planes are not parallel. Actually I found that blocks edges are not exactly on geometry surface [on symmetry plane].
The question is how should I associate blocks edges with curves, which are on symmetry plane?
The picture of geo and blocks is attached and edges which are in question are marked.
Thanks for any comment
Old   March 24, 2015, 07:01
Farzin
I think I've found the fault.
After associating the radial block edges on symmetry plane with nearby curves on the same plane, it seems alright and the CFX Solver works without any interruption.
But there is a considerable difference between the later model (half-pipe expansion with symmetry plane) and the whole pipe expansion.
The whole pipe result seems to be more accurate and realistic.
I extended this conversation to ANSYS CFX sub-forum, in a new thread.
http://www.cfd-online.com/Forums/cfx...expansion.html
Old   December 29, 2017, 13:36
Santosh
SKS13 is on a distinguished road
Can you please tell me the step by step procedure for meshing half pipe?
SKS13 is offline   Reply With Quote
expansion, icem cfd 14.5, meshing 3d, pipe
[ICEM] ICEM PIPE bend meshing firavia ANSYS Meshing & Geometry 3 December 23, 2012 09:29
[GAMBIT] Meshing 3-D pipe problem shayan_mv ANSYS Meshing & Geometry 7 August 18, 2012 13:33
[ICEM] Meshing a complex pipe network Industrial_CFD ANSYS Meshing & Geometry 0 January 31, 2012 15:59
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
How to model sudden expansion kvaswegen OpenFOAM Running, Solving & CFD 0 May 18, 2010 11:32
