[ICEM] Problem with holes in surfaces
Old   November 7, 2014, 05:54
Default Problem with holes in surfaces
Robert Bischof
biro is on a distinguished road
Hello there,
I have problems with surfaces in icem cfd.
For the k-epsilon simulation, I didn't need to resolve the inflation layer. So the mesh was coarse for wall distance.
Now I want to change to SST turbulence model and so I need to resolve the inflation layer and a low wall distance.
By refining my mesh it becames bad quality. I investigated the bad region and I found a problem with my surfaces. There are Holes in my Geometry. I think, the surface can't follow the spline I imported.
I import only curves from NX and built the surfaces on my own.
Is there a way to avoid this problem ?
biro is offline   Reply With Quote
Old   November 7, 2014, 08:57
Robert Bischof
Another Example at the edge of two surfaces.
The Elements are very small, because of a low wall distance in both direction.
You see, that there will be strange Elements, with bad quality.
There are only a few Elements, but its only at the regions, where the wall distance is very low ?
Are there problems in icem ?
I think, I'am not the first, who try to get a y+-value of ~1 ?!
Old   November 11, 2014, 02:33
Robert Bischof
Can nobody help me ? I still found no solution for my problem ?
Is there a special method for meshing near wall distance to get low y+ ?
Should I always use O-Grid method to mesh this regions ?
Old   November 11, 2014, 10:21
Ludvik is on a distinguished road
Extend surfaces through together. At intersection of these surfaces create curves. In Blocking for "Edge to Curve" switch ON "Project to Surface Intersection".
Ludvik is offline   Reply With Quote
Old   November 12, 2014, 02:59
Robert Bischof
I have tried to mesh with you tip, Ludvik, but it makes no difference.
I will give you more details of my geometry. It's a simple pipe. But I need the orange surface, it's my interface to the other part of geometry. Because of that I choose this blocking topology. I need a low wall distance in booth directions, I have drawn the red arrows.
The strange things only happens, when I reach a range, in which the elements will be very small and only at first series of elements. Often at the intersection of surfaces at the edges.
I try to make picture which shows my problem.
For help I will be very thankful. For now I can't find solution.
Old   November 12, 2014, 03:38
Robert Bischof
I found a solution:
With this thread http://www.cfd-online.com/Forums/ans...y-small-y.html
I activate the setting "Project to Bsplines" and set the "Projection limit" to 0.01.
Now it works fine!
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
How to set up meshes of sparse and small holes? leeyee FLOW-3D 1 September 2, 2010 22:50
Flow through multiple holes Matthew Markham Main CFD Forum 3 January 28, 2009 21:47
Multiple Sahdows / Periodicity Problem Michael Pi FLUENT 0 July 11, 2005 07:42
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
