[ICEM] Segmendation Violation Smoothing
Old   December 22, 2014, 14:14
Default Segmendation Violation Smoothing
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
When i run octree volume meshing after the mesh is created, when the automatic smoothing starts, my icem crashs with a "segmendation violation" error.
When i mesh with delauney ( without automatic smoothing in the mesh algorithm) no crash occurs until i try to smooth manual.
I would normally just restart my computer, but sadly im connected via teamviewer, because im 300 miles away from the pc and the restart would cut my connection.
Im back at my workstation at 06.01.15 but due to time limitation i can not wait until then.
The segmendation violation is as far as i now a problem with my memory. Is there a "quick and dirty solution" to solve this error without rebooting my system and losing my teamviewer connection? Maybe shut down some processes in windows ore something like that?
Chris_321 is offline   Reply With Quote
Old   December 23, 2014, 10:32
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
have you check if you have sufficient hard drive space left ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 25, 2014, 04:31
Chris_321's Avatar
Christian
I found someone to restart the workstation
Now everything works again but i still dont know whats caused this error.
Regards
[ANSYS Meshing] Smoothing options siw ANSYS Meshing & Geometry 3 August 13, 2019 07:40
[ANSYS Meshing] Smoothing and Post Smoothing siw ANSYS Meshing & Geometry 0 November 5, 2012 09:14
Dynamic mesh smoothing: what is really Spring-based smoothing?? Freeman FLUENT 10 March 30, 2009 07:47
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 10:23
How to use Hexa smoothing function? Nick CFX 2 October 5, 2004 23:47
