February 18, 2008, 07:36 |
[ICEM] export for fluent
I have a question about ICEM CFD. I just want to export a simple mesh in the *.msh fluent format. So: -> in output I chose the Fluent_V6 solver -> then file/export mesh And there is no possibility for Fluent MSH format ? How is it possible ? Thanx a lot Lionel |
February 18, 2008, 08:29 |
Re: [ICEM] export for fluent
You have to select tab "Output". Then click on first icon ("Select solver) and selcet Fluent_V6. Next step is click on last icon in the row ("Write input"). Written file would be *.msh file.
Marek |
February 18, 2008, 09:43 |
"Written file would be *.msh file"
Thank you for the tip... It seems that in fact, it first asks the *.uns file as input, and then it shows the dialog for translation. That's why I didn't understand it first Best, Lionel |
February 18, 2008, 10:42 |
The .uns is the ICEM format mesh. If you have multiple .uns files, you select which mesh you want to convert to Fluent .msh format.
It may be that if you have the ICEM native mesh already loaded into memory, that it just uses that by default... |
March 23, 2010, 13:06 |
Reply.
User_CFD
Hi all!
Let me,please, know chose "common Structural Solver"? I haven ICEM CFD 11.0. |
March 18, 2018, 10:26 |
Fluent mesh problem
Laghouat
Rep Power: 8 |
Hi all
With ICEM CFD, I want to output a mesh for Ansys Fluent so, I have this problem " WARNING: Mesh has uncovered faces." Please I need your help |
March 19, 2018, 03:35 |
Gert-Jan
Rep Power: 27 |
1) Do not hijack someone elses thread. Please start a new thread with a new topic.
2) You should go to Edit Mesh > Check Mesh There you should perform all the (default) checks and make sure you repair all errors. Uncovered faces in your case. Mostly you can skip the Possible problems. Good Luck, Gert-Jan |
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
[ICEM] Export mesh for IDEAS solver | loic | ANSYS Meshing & Geometry | 2 | July 29, 2011 17:08 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Importing I-DEAS unv file | hbetb | FLUENT | 1 | August 10, 2001 13:22 |
