[ICEM] Problem with 2D to 3D block conversion using Multizone |
March 12, 2015, 23:02 |
Arvind
Rep Power: 12 |
I am working with a hellically twisted elliptic tube geometry and followed the steps listed in the post http://www.cfd-online.com/Forums/ans...-geometry.html I did everything as mentioned by the user in the post but have problem converting the 2D mapped surface mesh into a 3D structured block using Multizone which when used gives only the O-grid and does not map the interior geometry. Please suggest if I need to make changes in the geometry or block to achieve a 3D grid shown in the earlier post. |
[blockMesh] Wedge-shaped block: Problem with skew faces | Reni | OpenFOAM Meshing & Mesh Conversion | 2 | October 28, 2014 12:53 |
Block Mesh Problem | Foamaholic | OpenFOAM Pre-Processing | 0 | October 29, 2013 16:37 |
Mesh conversion problem from Salome to openfoam | jishnusoni | OpenFOAM | 15 | March 3, 2010 01:53 |
[Gmsh] Conversion Problem | ARC | OpenFOAM Meshing & Mesh Conversion | 2 | February 19, 2010 06:39 |
Unit Conversion Problem | lambuhere | CFX | 0 | August 20, 2004 04:49 |
