[ANSYS Meshing] Inflation layer near gap with multizone mesh
Old   April 24, 2015, 09:32
Default Inflation layer near gap with multizone mesh
matmax-168 is on a distinguished road
I try to mesh an airfoil section with two components. The wing and the flap. The problem is the gap between the two parts. How can I create a flexible Inflation layer, which is able to align when its moving to the gap? I have tested this mesh with a tetra grid, then the prismlayer is adapting when it comes closer to the gap! But this does not work when I use Prism or Hex elements for a structured grid.
The Inflation is neccesary for high resolution at the wall,because I decided to use SST turbulence model.
Any help is thankfully welcome.
matmax-168 is offline   Reply With Quote
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
