April 24, 2015, 11:41 |
Exporting to TurboGrid
Bartosz
Rep Power: 11 |
Hello
I have created in Blademodeler Rotor and Stator of the fan with ExportPoints. Since it is in one Geometry block I have problems to export the rotor and stator to different Turbogrind - it only exports the ExportPoints which was created earlier (rotor). Is it possible to export from one Geometry to two TruboGrids? Anticipating the answer that I shoudl duplicate the Geometry and Suppress- I had made some dependencies between Rotor and Stator which are defined as parameters. Thanks for any help. Best regards |
May 4, 2015, 03:00 |
SG
Rep Power: 11 |
Hi adinacatslowo.
Yes, you can export from one geometry to two turbogrids. In workbench, open the "properties of Schematic: Turbo Mesh". There you have an option for geometry selection, and you can choose the appropriate FlowPath and Bladerow Number. Best regards, SG |
May 4, 2015, 11:05 |
Bartosz
Rep Power: 11 |
Thanks alot
Meshing or Topology generation error in TurboGrid? | jetcheve | CFX | 21 | July 24, 2021 09:08 |
[Other] TurboGrid - problem with trailing edges ending with hub/shroud curve | TTM | ANSYS Meshing & Geometry | 8 | February 16, 2020 07:11 |
Files input for Turbogrid | Jun_Milan | CFX | 0 | July 10, 2014 23:34 |
[GAMBIT] Exporting Turbogrid mesh to Gambit | yidiragawa | ANSYS Meshing & Geometry | 0 | April 19, 2014 12:25 |
Importing ICEM mesh in TurboGrid | ayothicfd | Main CFD Forum | 0 | October 8, 2011 10:23 |
