[ICEM] Penetrating elements in extruded mesh
Old   June 11, 2015, 05:19
Default Penetrating elements in extruded mesh
Umberto
cinclus is on a distinguished road
Dear all,
I was trying to extrude a 2D mesh which works fine when in two dimensions but, when I extrude it, shows quite a few penetrating elements which sprung up from nodes which apparently did not have any problem.
I enclose the a picture of the 2D mesh and what I obtain once extruded
I tried to look it up but didn't find any possible solution and most of the users having similar problems were using a hexa mesh, which I can't use as I'm implementing dynamic mesh.
Thank you all in advance
cinclus is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 04:58
