ICEM Meshing problem
Old   September 12, 2015, 06:55
Default ICEM Meshing problem
anurag
bhuwal_anurag is on a distinguished road
Hi all
I am having doubt how icem work regarding interface for heat transfer problem. I have created a concentric cylinder in icem and created mesh define two volume one solid to outside cylinder and inner cylinder as fluid for air to pass. I named part as outer cylinder,inner cylinder inlet outlet and imported to fluent it created only shadow part for inner cylinder but no interface, but when i used workbench and created same with design modeller and meshed and imported to fluent it created interface as part plus mesh interface option in fluent. but icem was not able to create interface as part plus mesh interface in fluent also.
both result where different also when i simulated with same condition.
I want to know do we have to create separately interface in icem for heat transfer and what is the method for it??
Thank you in advance
bhuwal_anurag is offline   Reply With Quote
Old   September 12, 2015, 10:04
Antanas is on a distinguished road
Originally Posted by bhuwal_anurag View Post
Hi all
http://www.cfd-online.com/Forums/ans...tml#post563101
Antanas is offline   Reply With Quote
ansys, icem 14.5, workbench 14.5
[ANSYS Meshing] ICEM Meshing problem drvincentip ANSYS Meshing & Geometry 1 May 2, 2013 17:31
[ICEM] Problem with ICEM Script Meshing asal ANSYS Meshing & Geometry 2 March 23, 2013 19:11
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
[ICEM] Meshing problem from ICEM CFD to Fluent cfdonlinederafa ANSYS Meshing & Geometry 2 September 21, 2010 16:16
ICEM meshing problem Forrest CFX 4 May 25, 2005 18:37
