[ICEM] Uncoverred faces and blocking problem
Old   September 11, 2015, 11:21
Default Uncoverred faces and blocking problem
Aman Jindal
Jinds is on a distinguished road
I am meshing an airfoil with deflected flap. There is a narrow slot upstream of the flap to blow high stream jets. The simulation is 2-D and I tried to generate structured mesh around it. Can someone suggest if my mesh is good enough to capture the flow behavior around the slot area. Also when I am exporting this mesh it says that I have uncovered faces and it gives error while reading in FLUENT.....
I would really appreciate if someone could help me out there!!
Thanks in advance
Jinds is offline   Reply With Quote
Old   September 11, 2015, 12:33
Antanas is on a distinguished road
Thanks in advance
I don't like mesh between red lines. It seems you have very small triangles there. Why?
Antanas is offline   Reply With Quote
Old   September 11, 2015, 13:04
Aman Jindal
Thanks for replying Antanas
Actually I am not very experienced in blocking, I just split the main O-grid block to fit around the airfoil + flap and the slot. Although I tried smoothing the mesh by moving the vertices and adjust the aspect ratio in that area (marked red by you).
But the main problem is in exporting the mesh when it says that I have uncovered edged, I don't know hoe to fix it.
Old   September 11, 2015, 15:04
Read ICEM Help Manual -> Edit Mesh -> Check Mesh -> Errors: Uncovered Faces
[ICEM] Triangle 2D blocking "face" problem Sawi ANSYS Meshing & Geometry 1 November 12, 2014 04:50
[ICEM] Blocking doesn't follow correctly when making minor changes to geometry Polarbear ANSYS Meshing & Geometry 1 May 25, 2014 13:09
[ICEM] Blocking technique for models with small number of faces badboyz31 ANSYS Meshing & Geometry 3 March 27, 2014 17:05
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] Hexa meshing blocking problem fergal ANSYS Meshing & Geometry 0 June 28, 2011 10:01
