September 12, 2015, 06:55 |
ICEM Meshing problem
anurag
Rep Power: 10 |
Hi all
I am having doubt how icem work regarding interface for heat transfer problem. I have created a concentric cylinder in icem and created mesh define two volume one solid to outside cylinder and inner cylinder as fluid for air to pass. I named part as outer cylinder,inner cylinder inlet outlet and imported to fluent it created only shadow part for inner cylinder but no interface, but when i used workbench and created same with design modeller and meshed and imported to fluent it created interface as part plus mesh interface option in fluent. but icem was not able to create interface as part plus mesh interface in fluent also. both result where different also when i simulated with same condition. I want to know do we have to create separately interface in icem for heat transfer and what is the method for it?? Thank you in advance |
September 12, 2015, 10:04 |
#2 | |
Rep Power: 18 |
ansys, icem 14.5, workbench 14.5 |
[ANSYS Meshing] ICEM Meshing problem | drvincentip | ANSYS Meshing & Geometry | 1 | May 2, 2013 17:31 |
[ICEM] Problem with ICEM Script Meshing | asal | ANSYS Meshing & Geometry | 2 | March 23, 2013 19:11 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 10:09 |
[ICEM] Meshing problem from ICEM CFD to Fluent | cfdonlinederafa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:16 |
ICEM meshing problem | Forrest | CFX | 4 | May 25, 2005 18:37 |
