[ANSYS Meshing] Some parts are showing transparent
Old   February 19, 2016, 09:00
Default Some parts are showing transparent
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
When I started meshing in ansys workbench meshing all parts r visible as shaded exterior I did some mesh trials and then I saw that some of my parts in Assembly are turned into transparent. I checked view option where shaded exterior is highlighted. How to make that particular part to normal view.
Help me
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   February 21, 2016, 13:46
Onur
Onurozcan is on a distinguished road
Help me
İf you are working on fluid rather than solid it will appear.That is not problem but if you want to change it you''ll see in left side ''TREE'' and there is a named ''connections'' you can button one click and there will be opened in page below ,change it enable ''no'' rather than yes
Onurozcan is offline   Reply With Quote
Old   February 22, 2016, 09:28
sunilpatil's Avatar
sunil
Hi thank you for your suggestions. The problem solved. By default the transparency level was set to very low so after changing that all the parts are visible.
Regards,
Sunil
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 0 March 4, 2011 07:48
How to get a selected part to be non- transparent? Chenthu STAR-CCM+ 2 January 25, 2011 08:29
Creating 100 derived parts / Splitting derived parts for mass flux calculation xamo STAR-CCM+ 8 September 29, 2009 05:35
[snappyHexMesh] SnappyHexMesh complex geometries amp thin wall parts hsieh OpenFOAM Meshing & Mesh Conversion 0 September 22, 2008 17:34
