[ANSYS Meshing] Inflation mesh with relate to Growth Rate
Old   December 12, 2015, 20:22
Default Inflation mesh with relate to Growth Rate
Onur
Onurozcan is on a distinguished road
I am working on 3d heat exchanger analysis.
I have given a value in total thickness in inflation mesh( with relate to y+)
As shown below, waste gas fluid domain mesh ( inflation) in vertical is rough/fluctant rather than the around tubes( that is diameter of tubes)
https://imageshack.com/i/paGgN1X1p
What should I do?
Growth rate/number of boundary layer should be decreased ? or something else?
As I have given a value in total thickness with relate to y+ or boundary layer number,
If I change growth rate/boundary layer , I am going to change total thickness that will be good if you give a valuable information.
Thanks,
Kind Regards,
Onurozcan is offline   Reply With Quote
Old   December 20, 2015, 21:20
hwet is on a distinguished road
Show your inflation layer bodies and faces selection as well, then someone might be able to tell why you are not getting the inflation layers at these faces.
and give more general info as well regarding the mesh.
hwet is offline   Reply With Quote
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[ANSYS Meshing] Failed mesh following inflation preview Nicki_p ANSYS Meshing & Geometry 2 January 8, 2017 09:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
controlling unstructured mesh growth tucker FLUENT 3 November 2, 2005 14:27
