[ICEM] negative Determinant 3x3x3 after applying O-grid
Old   January 12, 2016, 17:27
Default negative Determinant 3x3x3 after applying O-grid
Alexander Comsa
ticofiz is on a distinguished road
Dear all,
I have been trying to mesh a T-junction with ICEM. The mesh without O-grid has bad quality so I try to use an O-grid as explained in many threads. The problem is that I get negative Determinant 3x3x3 after that. Could you please tell me what I am doing wrong? The geometry is made in Ansys DM. I have two days experience with ICEM.
Best wishes,
C.
ticofiz is offline   Reply With Quote
Old   January 13, 2016, 02:18
Alexander Comsa
I have found the problem. I have not Blocked properly the geometry so some edges have not been associated with the proper curves. As soon as I split the Block as it should be, the negative determinant problem is gone. I still have to figure out why boundaries defined as parts in ICEM are not imported in FLUENT. But this is another problem.
Many thanks, at least for reading,
C.
icem 3d, meshing icem cfd, negative volumes
very small negative concentration when applying UDS for simulating passive scalar jasonwang Fluent UDF and Scheme Programming 1 July 3, 2023 00:35
applying 2nd order muscl scheme to 2D unstructured(triangle) grid dokeun Main CFD Forum 2 May 22, 2012 02:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
grid manipulation and applying boundary conditions Chetan Kadakia FLUENT 3 August 22, 2000 04:51
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 18:18
