[ANSYS Meshing] Missing edges in Meshing
Old   January 21, 2016, 03:38
Default Missing edges in Meshing
DrDevice is on a distinguished road
Hey guys,
I have been trying to mesh a multi-element aerofoil, but for some reason one of the edges which exists in DesignModeller doesn't appear in meshing. The edge in question needs to have a refinement on it, but because it no longer exists the mesh fails.
I have tried it with the endplate moved further in so that it overlaps, but to no avail. Any help is much appreciated.
There are some pictures showing the problem below.
DrDevice is offline   Reply With Quote
Old   January 22, 2016, 01:02
hwet is on a distinguished road
hmm what could be wrong with that.
I read somewhere that meshing may be affected by the graphic quality, try increasing this from the options menu, i think its is called "some" quality, cant be asked to look it up at the moment so sorry.
secondly, was this geometry made in a CAD package other than design modeler, if yes then you should repair the geometry in design modeler. you can repair edges, hard edges and points etc using the repair tool.
See if these solve the issue and post back if it does.
hwet is offline   Reply With Quote
Old   January 22, 2016, 06:55
I don't think its a graphics problem, even if I do refinement based on a named selection, it still misses the edge.
The geometry is from a 3D curve, so it is all in ANSYS. I got it to work in 15.0, but it still doesn't work in 16.1.
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Single Edges problem with Airfoil Meshing alijazizaib ANSYS Meshing & Geometry 2 March 16, 2015 06:32
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Boundary layer meshing with sharp trailing edges Andrew Berner FLUENT 1 August 28, 2007 17:39
Query on Meshing edges anthro FLUENT 0 January 26, 2007 23:02
